Hello, I am using hass.io on qnap. Hass.io is installed into Ubuntu Xenial container.
Supervisor version: 3.2.8
Homeassistant version: 0.103.5
19-12-29 12:39:20 INFO (SyncWorker_8) [hassio.docker.interface] Update image homeassistant/qemux86-64-homeassistant:landingpage to homeassistant/qemux86-64-homeassistant:0.103.5
The problem is that none of add-ons won’t startup (setting auto-startup is ON) - thus homassistant won’t startup too - cos it can not start recorder.
Hi Chorus,
I have a similar problem. My Hass.io installation is on a raspberry.
HA is not reachable, neither via browser nor via android app. The Pi itself can be pinged and connected to via SSH.
How did you check that log you show in your post?
I have attached to dockers with docker logs -f homeassistant
Finally I have skipped hass.io and made all working on docker-compose.
Run docker ps to see what dockers are running and you can connect to hass with docker exec -it homeassistant /bin/bash
