I recently moved my home assistant instance from the hass.io image on a RPI to Docker on my Ubuntu server.
I used the command
docker run -d --name="home-assistant" -v /PATH_TO_YOUR_CONFIG:/config -v /etc/localtime:/etc/localtime:ro --net=host homeassistant/home-assistant
To install and run home assistant with hass.io which initially worked but some of the addons didn’t work (which I think is because hass.io installed the arm addons not the AMD64 addons) so I removed the Docker containers and reinstalled home assistant and hassio using the same command as before. However this time the hassio tab was missing in the web interface - meaning LetsEncrypt, DuckDNS and all the other addons are not able to run. However the Hassio container is running and can be seen in portainer.
Also I still have
hassio:
in my configuration. I have managed to change the config so I can access homeassistant locally, and I can control my devices through Alexa and through the web interface when on my LAN but I would like to get hassio back up so that I can get my addons working and use it for other useful things (such as updates and snapshots).
If anyone knows how to fix this any advice would be greatly appreciated!!
