HASS.IO -> transfer from SD card to SSD or USB
Dear all,
I have tried to migrate from SD to SSD, and finally I turn back to SD.
I have the following external devices:
  1. PI 4 4 GB ram.
  2. ConBee II Zigbee USB dongle.
  3. Sigma Designs Zwave Plus USB dongle.
These devices workks without problem with HA system 32 bits on SD.
For the migration I bought:
  1. ELUTENG Cables USB to SATA for 2.5 SATA SSD/HDD
  2. Crucial BX500 240 GB CT240BX500 SSD disk
The tutorial for the migration that I try was: https://community.home-assistant.io/t/installing-home-assistant-on-a-rpi-4b-8gb-with-ssd-boot/230948
With this tutorial I installed the HA version: hassos_rpi4-64-5.5.img.gz but I tried also the version hassos_rpi4-64-5.3.img.gz.
When I restore my last snapshot from the old system (32 bits), HA starts without problem from the SSD but with the following problems:
  1. My Sigma Designs - Z-Wave Plus USB dongle dont works, then all my zwave devices are misssing and I can’t start from scratch because I can’t add devices, delete old devices, etc. I tried to connect the zwave usb dongle to a extension USB cable and don’t works. Change the port from USB 3 to USB 2 and don’t works… The zigbee dongle works well and I can see all my zigbee devices.
  2. HACS integration don’t starts, and I need to unistall and install another time.
  3. AEMET integration don’t works
  4. The system is not fast than with SD card, proably because all the erros when starts. The upload time in browser for the Web UI is very slow, probably about 30 seconds or more. I deleted the database according with some tutorials, but this solve some errors, but the starting time to load the web interface is the same.
example of errors:
2020-11-14 04:19:39 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for variable which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-11-14 04:19:39 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-11-14 04:19:39 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for nodered which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-11-14 04:19:39 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for badnest which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-11-14 04:19:39 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for smartir which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-11-14 04:19:44 WARNING (MainThread) [homeassistant.components.climate] ClimateDevice is deprecated, modify NestClimate to extend ClimateEntity
2020-11-14 04:19:45 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for bwalarm which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-11-14 04:19:48 ERROR (MainThread) [custom_components.smartir] An error occurred while checking for updates.
2020-11-14 04:19:53 WARNING (MainThread) [homeassistant.components.broadlink.switch] The switch platform is deprecated, except for custom IR/RF switches. Please refer to the Broadlink documentation to catch up
2020-11-14 04:20:14 WARNING (SyncWorker_19) [homeassistant.components.bluetooth_le_tracker.device_tracker] No Bluetooth LE devices to track!
2020-11-14 04:20:14 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform legacy
2020-11-14 04:20:16 ERROR (MainThread) [homeassistant.components.calendar] google: Error on device update!
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 357, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 466, in async_device_update
await task
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/google/calendar.py", line 106, in update
self.data.update()
File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 239, in wrapper
result = method(*args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/google/calendar.py", line 175, in update
result = events.list(**params).execute()
File "/usr/local/lib/python3.8/site-packages/oauth2client/_helpers.py", line 133, in positional_wrapper
return wrapped(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/googleapiclient/http.py", line 842, in execute
raise HttpError(resp, content, uri=self.uri)
googleapiclient.errors.HttpError: <HttpError 404 when requesting https://www.googleapis.com/calendar/v3/calendars/616jclechijai43018fn6rr4m57e0mio%40import.calendar.google.com/events?orderBy=startTime&maxResults=5&singleEvents=true&timeMin=2020-11-14T04%3A20%3A16.480347%2B01%3A00&alt=json returned "Not Found">
2020-11-14 04:21:36 ERROR (MainThread) [metno] https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned Cannot connect to host aa015h6buqvih86i1.api.met.no:443 ssl:default [Name does not resolve]
2020-11-14 04:21:37 ERROR (MainThread) [metno] https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned Cannot connect to host aa015h6buqvih86i1.api.met.no:443 ssl:default [Name does not resolve]
2020-11-14 06:44:44 ERROR (MainThread) [homeassistant.helpers.entity] Update for climate.dining_room_thermostat fails
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 278, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 474, in async_device_update
raise exc
File "/config/custom_components/badnest/climate.py", line 325, in update
self.device.update()
File "/config/custom_components/badnest/api.py", line 210, in update
for bucket in r.json()["updated_buckets"]:
File "/usr/local/lib/python3.8/site-packages/requests/models.py", line 898, in json
return complexjson.loads(self.text, **kwargs)
File "/usr/local/lib/python3.8/site-packages/simplejson/__init__.py", line 525, in loads
return _default_decoder.decode(s)
File "/usr/local/lib/python3.8/site-packages/simplejson/decoder.py", line 370, in decode
obj, end = self.raw_decode(s)
File "/usr/local/lib/python3.8/site-packages/simplejson/decoder.py", line 400, in raw_decode
return self.scan_once(s, idx=_w(s, idx).end())
simplejson.errors.JSONDecodeError: Expecting value: line 2 column 1 (char 1)
2020-11-14 08:09:37 ERROR (MainThread) [metno] https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned Cannot connect to host aa015h6buqvih86i1.api.met.no:443 ssl:default [Name does not resolve]
2020-11-14 09:27:15 ERROR (MainThread) [homeassistant] Error doing job: Unclosed connection
2020-11-14 10:01:13 ERROR (MainThread) [homeassistant] Error doing job: Unclosed connection
For these reasons I decided to turn back to SD and wait to a stable version.
This was my experience with the migtration…
