I have an Intel NUC running Ubuntu Server 18.04 on which I installed hass.io along with a number of addons. It’s been running fine until today, when I decided to reboot it. It never came back up and eventually I tried deleting /usr/share/hassio and then reinstalling and restoring a snapshot. However I end up back at the same situation.
I have now tried a new PC with a clean install which also works fine until I restore, and then it does the same thing. The homeassistant docker logs show
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.loader] Loaded weather from homeassistant.components.weather,
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.loader] Loaded alarm_control_panel from homeassistant.components.alarm_control_panel,
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.loader] Loaded light from homeassistant.components.light,
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.loader] Loaded group from homeassistant.components.group,
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.loader] Loaded scene from homeassistant.components.scene,
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.loader] Loaded automation from homeassistant.components.automation,
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor,
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.loader] Loaded panel_iframe from homeassistant.components.panel_iframe,
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.loader] Loaded binary_sensor from homeassistant.components.binary_sensor,
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.loader] Loaded input_text from homeassistant.components.input_text,
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.loader] Loaded input_number from homeassistant.components.input_number,
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api,
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized,
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend,
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api,
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http,
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log,
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.loader] Loaded auth from homeassistant.components.auth,
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding,
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace,
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.loader] Loaded logger from homeassistant.components.logger,
2019-02-16 21:40:19 INFO (MainThread) [homeassistant.setup] Setting up logger,,
al/lib/python3.6/site-packages/urllib3/connectionpool.py:847: InsecureRequestWarning: Unverified HTTPS request is being made. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/latest/advanced-usage.html#ssl-warnings,
InsecureRequestWarning),,
I have tried snapshots going back ten days, and they all do the same thing. Running docker -ps shows that homeassistant is not listening on port 8123:
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
a55d3233a5ce homeassistant/qemux86-64-homeassistant "/bin/entry.sh pytho…" 16 minutes ago Up About a minute homeassistant
e8b8e0ad192e hassioaddons/jupyterlablite "/init" 24 minutes ago Up 24 minutes 0.0.0.0:7777->7777/tcp addon_a0d7b954_jupyterlablite
91a84e14b68a homeassistant/amd64-addon-mariadb "/usr/bin/entry.sh /…" 24 minutes ago Up 24 minutes 0.0.0.0:3306->3306/tcp addon_core_mariadb
17975afa9daa hassioaddons/node-red-amd64 "/init" 25 minutes ago Up 7 minutes addon_a0d7b954_nodered
a7c1a89e5f7c hassioaddons/log-viewer "/init" 25 minutes ago Up 25 minutes 0.0.0.0:4277->4277/tcp addon_a0d7b954_logviewer
b55f8df7f106 homeassistant/amd64-addon-configurator "/run.sh" 25 minutes ago Up 25 minutes 0.0.0.0:3218->3218/tcp addon_core_configurator
c3683492593a portainer/portainer "/portainer" 33 minutes ago Up 33 minutes 0.0.0.0:9001->9000/tcp portainer
194cbaead48e homeassistant/amd64-hassio-supervisor "python3 -m hassio" 39 minutes ago Up 54 seconds hassio_supervisor
Help!
