I get the following in the logs when I check the terminal. Does anyone know how I can solve this?
I already restored a snapshot of a working installation from yesterday, but that also did not help.
File "/usr/local/lib/python3.7/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/local/lib/python3.7/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/usr/local/lib/python3.7/site-packages/homeassistant/__main__.py", line 397, in <module>
sys.exit(main())
File "/usr/local/lib/python3.7/site-packages/homeassistant/__main__.py", line 371, in main
args = get_arguments()
File "/usr/local/lib/python3.7/site-packages/homeassistant/__main__.py", line 103, in get_arguments
import homeassistant.config as config_util
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 724, in exec_module
File "<frozen importlib._bootstrap_external>", line 857, in get_code
File "<frozen importlib._bootstrap_external>", line 525, in _compile_bytecode
ValueError: bad marshal data (invalid reference)
sys.exit(main())
EDIT: Did a image restore that I made earlier. Lost some data, but the system is still a test setup. So not a really big problem.
