Hass.io wifi with wpa-psk2 config?
how can i configure hass to connect my wpa-psk2 secure wifi ? I am able to do only wpa-psk.
Thank You
Did you try it with wpa-psk? Im running WPA2 and it works.
I’m also trying to connect an WPA2 PSK wireless network and it’s not conecting
It’s the same. I have just checked it with a fresh install and a WPA2-only network configured on OpenWRT. If your WiFi doesn’t load, 99% sure it is not an issue with WPA2 but with your config file in general. There is no need to change the config parameters.
(I know, it’s an old thread but I would like to make sure people are not discouraged to use WPA2 or wifi when they come here).
