I have made my Hass.io accessible via DuckDNS addon with LetsEncrypt SSL. For the most part this worked (although requiring SSL breaks pretty much everything else like Node Red editor and Configurator).
Of course this immediately caused the next common problem that my router doesn’t support loop back, and I didn’t want to use two different URLs. Next I install DNSMasq add on and configure my router to use the Hass.io IP as a DNS server; secondary is Google public DNS.
At this point I hit problems. While connected to my local network using the https://myhass.duckdns.org
address I am able to reach the old UI, but as soon as I change to Lovelace the UI just shows the HA logo and says "Unable to Connect " with a retry button that does nothing.
Does Lovelace UI not work on the local network with DuckDNS/Letsencrypt SSL and DNSMasq? Connecting from phone 4G Lovelace is served properly.
Also it should be mentioned that DuckDNS and Android Chome “add to homescreen” doesn’t work properly. `Manifest.json’ must not install correctly because the home screen icon opens in the browser instead of app mode. Can anyone confirm this?
I have also wasted countless hours trying every combination of settings to get my Node Red and Configurator iFrames working with no luck, but I guess that’s another topic.
