I’m using Hasss.io (v166) with Grafana (2.1.4) and Influxdb (3.0.5) add-ons but cannot see any sensor data appearing in my Influxdb Explore option. I’m new to this config but just about pulling my hair out with not getting any results into Influx or Grafana.
In InfluxDB, I’ve setup my Grafana user (homeassistant) and database (homeassistant) and added the following to my configuration.yaml…
influxdb:
host: a0d7b954-influxdb
port: 8086
database: homeassistant
username: homeassistant
password: xxxxxxxxxxxx
max_retries: 5
default_measurement: state
…and the InfluxDB config is…
"auth": true,
"reporting": true,
"ssl": false,
"certfile": "fullchain.pem",
"keyfile": "privkey.pem"
…and successfully configured (I think) my Grafana data source as I get the green bar saying my data source is working. My data source has config details of…
Name - InfluxDB
URL - http://a0d7b954-influxdb:8086
Database - homeassistant
However, in Influxdb, when looking to see if any data is being transferred from Home Assistant into Influxdb using Explore, I see absolutely nothing. When using the Influxdb/Explore meta query template, I can sucessfully apply the query “Show Databases” which displays “homeassistant”.
However, when applying query “SHOW MEASUREMENTS ON homeassistant” it returns a message “Your query is syntactically correct but returned no results”.
I need help in resolving how to test where the problem is occurring, even if it’s a pointer towards more documentation on how to integrate Grafana, Influxdb and Hass.io a there seems to be very little info on this.
I’ve provided the Grafana and Influxdb logs below just in case they reveal something I can’t see or understand.
Grafana LOG…
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Hass.io Add-on: Grafana
The open platform for beautiful analytics and monitoring
Add-on version: 2.1.4
You are running the latest version of this add-on.
System: HassOS 2.12 (armv7 / raspberrypi3)
Home Assistant version: 0.94.3
Supervisor version: 166
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] grafana.sh: executing...
[cont-init.d] grafana.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[17:40:49] INFO: Starting Memcached...
[17:40:50] INFO: Starting Grafana...
t=2019-06-16T17:40:55+0100 lvl=info msg="Starting Grafana" logger=server version=6.2.2 commit=07540df branch=HEAD compiled=2019-06-05T14:04:21+0100
t=2019-06-16T17:40:55+0100 lvl=info msg="Config loaded from" logger=settings file=/usr/share/grafana/conf/defaults.ini
t=2019-06-16T17:40:55+0100 lvl=info msg="Config loaded from" logger=settings file=/etc/grafana/grafana.ini
t=2019-06-16T17:40:55+0100 lvl=info msg="Path Home" logger=settings path=/usr/share/grafana
t=2019-06-16T17:40:55+0100 lvl=info msg="Path Data" logger=settings path=/data
t=2019-06-16T17:40:55+0100 lvl=info msg="Path Logs" logger=settings path=/var/logs/grafana
t=2019-06-16T17:40:55+0100 lvl=info msg="Path Plugins" logger=settings path=/var/lib/grafana/plugins
t=2019-06-16T17:40:55+0100 lvl=info msg="Path Provisioning" logger=settings path=/usr/share/grafana/conf/provisioning
t=2019-06-16T17:40:55+0100 lvl=info msg="App mode production" logger=settings
t=2019-06-16T17:40:55+0100 lvl=info msg="Initializing SqlStore" logger=server
t=2019-06-16T17:40:55+0100 lvl=info msg="Connecting to DB" logger=sqlstore dbtype=sqlite3
t=2019-06-16T17:40:55+0100 lvl=info msg="Starting DB migration" logger=migrator
t=2019-06-16T17:40:55+0100 lvl=info msg="Initializing HTTPServer" logger=server
t=2019-06-16T17:40:56+0100 lvl=info msg="Initializing InternalMetricsService" logger=server
t=2019-06-16T17:40:56+0100 lvl=info msg="Initializing RemoteCache" logger=server
t=2019-06-16T17:40:56+0100 lvl=info msg="Initializing QuotaService" logger=server
t=2019-06-16T17:40:56+0100 lvl=info msg="Initializing LoginService" logger=server
t=2019-06-16T17:40:56+0100 lvl=info msg="Initializing PluginManager" logger=server
t=2019-06-16T17:40:56+0100 lvl=info msg="Starting plugin search" logger=plugins
t=2019-06-16T17:40:56+0100 lvl=info msg="Plugin dir created" logger=plugins dir=/var/lib/grafana/plugins
t=2019-06-16T17:40:56+0100 lvl=info msg="Initializing RenderingService" logger=server
t=2019-06-16T17:40:56+0100 lvl=info msg="Initializing AlertingService" logger=server
t=2019-06-16T17:40:56+0100 lvl=info msg="Initializing DatasourceCacheService" logger=server
t=2019-06-16T17:40:56+0100 lvl=info msg="Initializing HooksService" logger=server
t=2019-06-16T17:40:56+0100 lvl=info msg="Initializing SearchService" logger=server
t=2019-06-16T17:40:56+0100 lvl=info msg="Initializing ServerLockService" logger=server
t=2019-06-16T17:40:56+0100 lvl=info msg="Initializing TracingService" logger=server
t=2019-06-16T17:40:56+0100 lvl=info msg="Initializing UsageStatsService" logger=server
t=2019-06-16T17:40:56+0100 lvl=info msg="Initializing UserAuthTokenService" logger=server
t=2019-06-16T17:40:56+0100 lvl=info msg="Initializing CleanUpService" logger=server
t=2019-06-16T17:40:56+0100 lvl=info msg="Initializing NotificationService" logger=server
t=2019-06-16T17:40:56+0100 lvl=info msg="Initializing provisioningServiceImpl" logger=server
t=2019-06-16T17:40:57+0100 lvl=info msg="Initializing Stream Manager"
t=2019-06-16T17:40:57+0100 lvl=info msg="HTTP Server Listen" logger=http.server address=0.0.0.0:80 protocol=http subUrl= socket=
t=2019-06-16T18:29:02+0100 lvl=eror msg="failed to look up user based on cookie" logger=context error="user token not found"
t=2019-06-16T18:29:02+0100 lvl=info msg="Request Completed" logger=context userId=0 orgId=0 uname= method=GET path=/ status=302 remote_addr=192.168.1.100 time_ms=18 size=57 referer=http://192.168.1.120:8123/hassio/addon/a0d7b954_grafana
t=2019-06-16T18:29:13+0100 lvl=info msg="Request Completed" logger=context userId=1 orgId=1 uname=admin method=GET path=/api/datasources/proxy/10/query status=401 remote_addr=192.168.1.100 time_ms=1521 size=33 referer="http://192.168.1.120:3000/?orgId=1"
t=2019-06-16T18:29:35+0100 lvl=eror msg="Basic auth failed" logger=context error="User not found"
t=2019-06-16T18:29:35+0100 lvl=info msg="Request Completed" logger=context userId=0 orgId=0 uname= method=GET path=/api/datasources/proxy/10/query status=401 remote_addr=192.168.1.100 time_ms=3 size=31 referer="http://192.168.1.120:3000/?orgId=1"
t=2019-06-16T18:30:50+0100 lvl=eror msg="Basic auth failed" logger=context error="User not found"
t=2019-06-16T18:30:50+0100 lvl=info msg="Request Completed" logger=context userId=0 orgId=0 uname= method=GET path=/api/datasources/proxy/10/query status=401 remote_addr=192.168.1.100 time_ms=1 size=31 referer=http://192.168.1.120:3000/datasources/edit/10/
t=2019-06-16T19:32:39+0100 lvl=eror msg="Basic auth failed" logger=context error="User not found"
t=2019-06-16T19:32:39+0100 lvl=info msg="Request Completed" logger=context userId=0 orgId=0 uname= method=GET path=/api/datasources/proxy/10/query status=401 remote_addr=192.168.1.100 time_ms=3 size=31 referer=http://192.168.1.120:3000/datasources/edit/10/
t=2019-06-16T19:36:59+0100 lvl=eror msg="Basic auth failed" logger=context error="User not found"
t=2019-06-16T19:36:59+0100 lvl=info msg="Request Completed" logger=context userId=0 orgId=0 uname= method=GET path=/api/datasources/proxy/10/query status=401 remote_addr=192.168.1.100 time_ms=1 size=31 referer=http://192.168.1.120:3000/datasources/edit/10/
Influxdb LOG…
time="2019-06-16T20:32:37+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51854" response_time="140.937µs" status=200
[16/Jun/2019:20:32:37 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:32:47+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51856" response_time="76.666µs" status=200
[16/Jun/2019:20:32:47 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:32:57+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51858" response_time="83.749µs" status=200
[16/Jun/2019:20:32:57 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:33:07+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51860" response_time="153.02µs" status=200
[16/Jun/2019:20:33:07 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:38:37+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51910" response_time="338.956µs" status=200
[16/Jun/2019:20:38:37 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1 HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:38:38+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51912" response_time="145.519µs" status=200
[16/Jun/2019:20:38:38 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:38:38+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51914" response_time=5.485998ms status=200
[16/Jun/2019:20:38:38 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/sources HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:38:38+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51918" response_time=3.05232ms status=200
time="2019-06-16T20:38:38+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:51922" url=/laser-spinner.0560a4d9.png
[16/Jun/2019:20:38:38 +0100] 499 192.168.1.100, 172.30.32.1(172.30.32.2) GET /laser-spinner.0560a4d9.png HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:38:38+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51922" response_time=83.526583ms status=200
time="2019-06-16T20:38:38+01:00" level=info msg="Response: No Content" component=server method=GET remote_addr="127.0.0.1:51936" response_time=2.263055ms status=204
[16/Jun/2019:20:38:38 +0100] 204 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/sources/0/health HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:38:38+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51938" response_time="577.652µs" status=200
[16/Jun/2019:20:38:38 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/sources/0/kapacitors HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:38:38+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:51940" response_time=6.616198ms status=200
[16/Jun/2019:20:38:38 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) POST /chronograf/v1/sources/0/proxy HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:38:38+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:51942" response_time=6.982862ms status=200
time="2019-06-16T20:38:39+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:51944" url=/Roboto-Medium.7030d125.ttf
[16/Jun/2019:20:38:39 +0100] 499 192.168.1.100, 172.30.32.1(172.30.32.2) GET /Roboto-Medium.7030d125.ttf HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:38:39+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51944" response_time=507.896945ms status=200
time="2019-06-16T20:38:40+01:00" level=info msg="Response: No Content" component=server method=GET remote_addr="127.0.0.1:51946" response_time=1.162803ms status=204
[16/Jun/2019:20:38:40 +0100] 204 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/sources/0/health HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:38:41+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:51950" response_time=5.497822ms status=200
[16/Jun/2019:20:38:41 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) POST /chronograf/v1/sources/0/proxy HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:38:41+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:51952" response_time=5.462404ms status=200
time="2019-06-16T20:38:41+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:51954" response_time=4.752619ms status=200
time="2019-06-16T20:38:41+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:51956" response_time=4.550069ms status=200
[16/Jun/2019:20:38:48 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:38:48+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51958" response_time="149.53µs" status=200
time="2019-06-16T20:38:58+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51964" response_time="163.592µs" status=200
[16/Jun/2019:20:38:58 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:39:08+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51966" response_time="75.624µs" status=200
[16/Jun/2019:20:39:08 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:39:18+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51968" response_time="135.26µs" status=200
[16/Jun/2019:20:39:18 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:39:28+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51970" response_time="75.156µs" status=200
[16/Jun/2019:20:39:28 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:39:38+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51972" response_time="74.323µs" status=200
[16/Jun/2019:20:39:38 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:39:48+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51974" response_time="76.77µs" status=200
[16/Jun/2019:20:39:48 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:39:58+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51978" response_time="81.718µs" status=200
[16/Jun/2019:20:39:58 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:40:08+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51980" response_time="76.458µs" status=200
[16/Jun/2019:20:40:08 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:40:18+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51982" response_time="78.229µs" status=200
[16/Jun/2019:20:40:18 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:40:28+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51984" response_time="73.124µs" status=200
[16/Jun/2019:20:40:28 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:40:36+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:51986" response_time="482.965µs" status=200
[16/Jun/2019:20:40:36 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) POST /chronograf/v1/sources/0/queries HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:40:38+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:51988" response_time=5.273604ms status=200
[16/Jun/2019:20:40:38 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) POST /chronograf/v1/sources/0/proxy HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:40:39+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51990" response_time="135.989µs" status=200
[16/Jun/2019:20:40:39 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:40:49+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51992" response_time="91.77µs" status=200
[16/Jun/2019:20:40:49 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:40:59+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51996" response_time="168.697µs" status=200
[16/Jun/2019:20:40:59 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:41:09+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:52002" response_time="135.78µs" status=200
[16/Jun/2019:20:41:09 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:41:18+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:52004" response_time="498.121µs" status=200
[16/Jun/2019:20:41:18 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) POST /chronograf/v1/sources/0/queries HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:41:18+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:52006" response_time=6.480051ms status=200
[16/Jun/2019:20:41:18 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) POST /chronograf/v1/sources/0/proxy HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:41:19+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:52008" response_time="141.093µs" status=200
[16/Jun/2019:20:41:19 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:41:29+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:52010" response_time="77.812µs" status=200
[16/Jun/2019:20:41:29 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:41:39+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:52012" response_time="147.708µs" status=200
[16/Jun/2019:20:41:39 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:41:49+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:52016" response_time="296.56µs" status=200
[16/Jun/2019:20:41:49 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:42:00+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:52018" response_time="137.238µs" status=200
[16/Jun/2019:20:42:00 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:42:10+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:52022" response_time="146.458µs" status=200
[16/Jun/2019:20:42:10 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:42:20+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:52024" response_time="134.894µs" status=200
[16/Jun/2019:20:42:20 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:42:30+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:52026" response_time="131.405µs" status=200
[16/Jun/2019:20:42:30 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:42:40+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:52028" response_time="131.249µs" status=200
[16/Jun/2019:20:42:40 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:42:50+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:52030" response_time="226.405µs" status=200
[16/Jun/2019:20:42:50 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
time="2019-06-16T20:43:00+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:52032" response_time="135.833µs" status=200
[16/Jun/2019:20:43:00 +0100] 200 192.168.1.100, 172.30.32.1(172.30.32.2) GET /chronograf/v1/me HTTP/1.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:67.0) Gecko/20100101 Firefox/67.0)
