Hass.io with LetsEncrypt & Sonos TTS
Does anyone have a working solution for using Sonos TTS with a ssl enabled (LetsEncrypt cert) hass.io installation?
The problem i believe is due to the Sonos not trusting one of the Root CAs, the fix on other installations is to copy the entire certificate chain into a single file. As i’m using Hass.io with the LetsEncrypt addon i’m not sure how feasible this is?
