Hass.io with Mosquitto broker 4.2 and Sonoff TasmotaPOW
I want to AutoDiscover my Sonoff POW.
I installed Mosquitto broker 4.2 with this config.
  "logins": [
      "username": "xxx",
      "password": "xxx"
  "anonymous": false,
  "quiet_logs": true,
  "customize": {
    "active": true,
    "folder": "mosquitto"
  "certfile": "fullchain.pem",
  "keyfile": "privkey.pem"
I followed the Instructions and did the ACLS Stuff.
Added a new User and also added the user in my SonoffPow.
On my Sonoff i did SetOption19 1 with this LOG.
17:17:31 MQT: sonoff/stat/RESULT = {"SetOption19":"ON"}
17:17:32 MQT: homeassistant/switch/56EB8D_RL_8/config =  (retained)
17:17:32 RSL: homeassistant/sensor/56EB8D_ENERGY_TotalStartTime/config = {"name":"Sonoff_POW_1 ENERGY TotalStartTime","stat_t":"~SENSOR","avty_t":"~LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"56EB8D_ENERGY_TotalStartTime","device":{"identifiers":["56EB8D"]}, "~":"sonoff/tele/","unit_of_meas":" ","val_tpl":"{{value_json['ENERGY'].TotalStartTime}}"}
17:17:32 RSL: homeassistant/sensor/56EB8D_ENERGY_Total/config = {"name":"Sonoff_POW_1 ENERGY Total","stat_t":"~SENSOR","avty_t":"~LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"56EB8D_ENERGY_Total","device":{"identifiers":["56EB8D"]}, "~":"sonoff/tele/","unit_of_meas":"kWh","val_tpl":"{{value_json['ENERGY'].Total}}"}
17:17:32 RSL: homeassistant/sensor/56EB8D_ENERGY_Yesterday/config = {"name":"Sonoff_POW_1 ENERGY Yesterday","stat_t":"~SENSOR","avty_t":"~LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"56EB8D_ENERGY_Yesterday","device":{"identifiers":["56EB8D"]}, "~":"sonoff/tele/","unit_of_meas":"kWh","val_tpl":"{{value_json['ENERGY'].Yesterday}}"}
17:17:32 RSL: homeassistant/sensor/56EB8D_ENERGY_Today/config = {"name":"Sonoff_POW_1 ENERGY Today","stat_t":"~SENSOR","avty_t":"~LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"56EB8D_ENERGY_Today","device":{"identifiers":["56EB8D"]}, "~":"sonoff/tele/","unit_of_meas":"kWh","val_tpl":"{{value_json['ENERGY'].Today}}"}
17:17:32 RSL: homeassistant/sensor/56EB8D_ENERGY_Power/config = {"name":"Sonoff_POW_1 ENERGY Power","stat_t":"~SENSOR","avty_t":"~LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"56EB8D_ENERGY_Power","device":{"identifiers":["56EB8D"]}, "~":"sonoff/tele/","unit_of_meas":"W","val_tpl":"{{value_json['ENERGY'].Power}}"}
17:17:32 RSL: homeassistant/sensor/56EB8D_ENERGY_ApparentPower/config = {"name":"Sonoff_POW_1 ENERGY ApparentPower","stat_t":"~SENSOR","avty_t":"~LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"56EB8D_ENERGY_ApparentPower","device":{"identifiers":["56EB8D"]}, "~":"sonoff/tele/","unit_of_meas":" ","val_tpl":"{{value_json['ENERGY'].ApparentPower}}"}
17:17:32 RSL: homeassistant/sensor/56EB8D_ENERGY_ReactivePower/config = {"name":"Sonoff_POW_1 ENERGY ReactivePower","stat_t":"~SENSOR","avty_t":"~LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"56EB8D_ENERGY_ReactivePower","device":{"identifiers":["56EB8D"]}, "~":"sonoff/tele/","unit_of_meas":" ","val_tpl":"{{value_json['ENERGY'].ReactivePower}}"}
17:17:32 RSL: homeassistant/sensor/56EB8D_ENERGY_Factor/config = {"name":"Sonoff_POW_1 ENERGY Factor","stat_t":"~SENSOR","avty_t":"~LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"56EB8D_ENERGY_Factor","device":{"identifiers":["56EB8D"]}, "~":"sonoff/tele/","unit_of_meas":" ","val_tpl":"{{value_json['ENERGY'].Factor}}"}
17:17:32 RSL: homeassistant/sensor/56EB8D_ENERGY_Voltage/config = {"name":"Sonoff_POW_1 ENERGY Voltage","stat_t":"~SENSOR","avty_t":"~LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"56EB8D_ENERGY_Voltage","device":{"identifiers":["56EB8D"]}, "~":"sonoff/tele/","unit_of_meas":"V","val_tpl":"{{value_json['ENERGY'].Voltage}}"}
17:17:32 RSL: homeassistant/sensor/56EB8D_ENERGY_Current/config = {"name":"Sonoff_POW_1 ENERGY Current","stat_t":"~SENSOR","avty_t":"~LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"56EB8D_ENERGY_Current","device":{"identifiers":["56EB8D"]}, "~":"sonoff/tele/","unit_of_meas":"A","val_tpl":"{{value_json['ENERGY'].Current}}"}
17:17:32 RSL: homeassistant/sensor/56EB8D_status/config = {"name":"Sonoff_POW_1 status","stat_t":"~HASS_STATE","avty_t":"~LWT","pl_avail":"Online","pl_not_avaiThis text will be hiddenl":"Offline","json_attributes_topic":"~HASS_STATE","unit_of_meas":" ","val_tpl":"{{value_json['RSSI']}}","uniq_id":"56EB8D_status","device":{"identifiers":["56EB8D"],"name":"Sonoff_POW_1","model":"Sonoff Pow R2","sw_version":"6.5.0(sonoff)","manufacturer":"Tasmota"}, "~":"sonoff/tele/"}
This is my Mosquitto Log:
[INFO] Setup mosquitto configuration
[WARN] SSL not enabled - No valid certs found!
[INFO] Found local users inside config
[INFO] Initialize Hass.io Add-on services
[INFO] Initialize Home Assistant discovery
[INFO] Start Mosquitto daemon
1556726717: mosquitto version 1.5.6 starting
1556726717: Config loaded from /etc/mosquitto.conf.
1556726717: |-- *** auth-plug: startup
1556726717: Opening ipv4 listen socket on port 1883.
1556726717: Opening ipv6 listen socket on port 1883.
1556726717: Opening websockets listen socket on port 1884.
1556726717: Warning: Mosquitto should not be run as root/administrator.
1556726719: New connection from 192.168.0.60 on port 1883.
[INFO] found mqtt_slave on local database
1556726720: New client connected from 192.168.0.60 as Sonor_Pow1 (c1, k15, u'mqtt_slave').
1556726744: New connection from 172.30.32.1 on port 1883.
[INFO] found homeassistant on local database
1556726745: Socket error on client <unknown>, disconnecting.
1556726745: New connection from 172.30.32.1 on port 1883.
1556726836: Client <unknown> has exceeded timeout, disconnecting.
1556726836: Socket error on client <unknown>, disconnecting.
1556726865: New connection from 172.30.32.1 on port 1883.
1556726866: Socket error on client <unknown>, disconnecting.
1556726866: New connection from 172.30.32.1 on port 1883.
1556726957: Client <unknown> has exceeded timeout, disconnecting.
1556726957: Socket error on client <unknown>, disconnecting.
1556726986: New connection from 172.30.32.1 on port 1883.
1556726987: Socket error on client <unknown>, disconnecting.
1556726987: New connection from 172.30.32.1 on port 1883.
1556727078: Client <unknown> has exceeded timeout, disconnecting.
1556727078: Socket error on client <unknown>, disconnecting.
1556727107: New connection from 172.30.32.1 on port 1883.
1556727108: Socket error on client <unknown>, disconnecting.
1556727108: New connection from 172.30.32.1 on port 1883.
I also have the feeling that I tried so many different things. Currently I don’t know what to do next, to get it work :confused:
Any Tips or typically made mistakes?
Cheers,
Mourkain
When setting up the MQTT broker in Hass frontend page: Configuration/Integrations/Mqtt.
Did you tick the check box to enable discovery?
I missed that once as well.
To remedy the mistake I just saved my config files and removed the MQTT broker and integration and reinstalled With the discovery box ticked.
Hope it helps.
Yeah, I have checked the Box and I also Disabled and Enabled the Integration.
Maybe I should try to completely reinstall the Mosquitto Broker.
I added this to my configuration.yaml
mqtt:
broker: core-mosquitto
username: ***
password: ***
I thought this isn‘t necessary anymore…
And I also made a firmware upgrade via the WebUI on the Tasmota, but it‘s still on 6.5.0
Ahh and i updated my Configurator to 3.3…
I dont‘t know why, but it works now =D
