Hi ! Since the last update ( 0.111 ) my home assistant won’t start completely … the ui is loading then I have a message that said ( something like that mine is in French ) : Hold on we are loading everything not everything will be available.
So my automation won’t work, my themes won’t apply ( it’s an automation so I get it ) my Xiaomi and harmony integration won’t work…
This is how you fix it. You don’t have to restore everything from a backup. Just issue this command at the cli to go to the previous version to see if it fixes your problem:
ha core update --version=0.110.7
If it does then you have a breaking change you need to fix before updating. So read the release notes and act accordingly.
If it does not restore your system then you have bigger issues.
