So in the last 36 hours my hassio install has crashed about 6 times. There is no one specific action that has triggered it. I have ,
Hit check config
Hit the configure button on the automatic prompt (due to bug we have to reconnect with Automatic api after restart)
Reloaded groups.
The only item that has been common is that the automatic integration has been running or was being configured (see item 2) when it crashes. Unfortunately, there is nothing in the home-assistant.log file. All of a sudden i see the Lost connection pop up and minutes later i see the error log pop up with the “Ended unfinished session” error.
I am currently on 0.52.1. Any guidance or pointers on how to troubleshoot would be appreciated.
I saw similar behavior after the recent update. Deleting the /config/home-assistant_v2.db file resolved it for me. Was never able to find an error message.
Did this end up working for you? I just ran into the issue again with the new update. Deleting the db file fixed it again, but I’m surprised not to see more reports of this issue.
Yep, stability returned instantly. I even tried the same actions that crashed it before. I have not updated since 52.1 (waiting for 53.1 to pop up for HASS.IO so i can fix the foscam issue) but i will retest once i upgrade.
