HASS + Konnected.io + Relay Switch - Keeps switching off
Hi all,
I’m fairly new to HA and in the process of migrating from SmartThings across to HA, loving it so far.
The Context:
I have a dashboard tablet which gets power from a relay-switched power source.
I used to switch this relay via WebCore on a schedule to exercise the battery.
This relay is connected via the Konnected.io board and successfully activates from HA when calling a script or service.
The Issue:
The Switch successfully flicks on, and charges the tablet. However it reverts to off again after a varied amount of time 10seconds out to 30 seconds.
config.yaml
konnected: !include konnected.yaml
Konnected.yaml
api_host: https://<localip>:8123 ### IP address of Home Assistant
access_token: !secret konnected_token
devices:
  - id: <mac removed> ### Alarm Panel
    host: x.y.z.73
    port: 18300
    binary_sensors:
      - zone: 1
        type: motion
      - zone: 2
        type: motion
      - zone: 3
        type: motion
    switches:
      - zone: 4
        activation: high
      - zone: 5
        momentary: 35
        pause: 55
        repeat: 4
      - zone: out
I’ve tried scripts, scenes and Service calls via the dev menu.
Each time, the relay successfully switches, then it turns off again (meaning the tablet never charges)
I can’t spot anything specific in the logs.
I’m not using MQTT, just the native integration (which I’m assuming the above yaml overwrites the config of) which i believe is an HTTP API post call?
Are there any logs I can enable that might hone in on post calls and responses?
I’ve seen in previous posts people saying MQTT didn’t receive a state reply… but this isn’t MQTT so I’m a tad lost.
Thanks in advance
No one have or had a similar issue?
