Where is the hass location on the Hassbian Pi image install. I want to restart the service for Home Assistant but can not find the service or location to run hass script checks from. I have been doing reboots but that is no good and I can’t script check.
The command:
```whereis hass`
Is not showing the location? Confused!?
I got it from @dale3h he reminded me to use the search/find then recommended using sudo ls -al /etc/systemd/system and I found it then he pointed me to a script to use hssctl to get the use of hass to restart my HA instance.
