This morning I’m getting persistent errors (below).
Notification:
Home Assistant Cloud
Unable to create a certificate. We will automatically retry it and notify you when it's available.
Errors:
2021-07-19 11:13:27 WARNING (Recorder) [homeassistant.components.recorder.migration] Database is about to upgrade. Schema version: 13
2021-07-19 11:13:30 ERROR (SyncWorker_0) [hass_nabucasa.acme] Can't connect to ACME server: urn:acme:error:serverInternal :: The server experienced an internal error :: The service is down for maintenance or had an internal error. Check https://letsencrypt.status.io/ for more details.
2021-07-19 11:13:41 ERROR (SyncWorker_2) [hass_nabucasa.acme] Can't connect to ACME server: urn:acme:error:serverInternal :: The server experienced an internal error :: The service is down for maintenance or had an internal error. Check https://letsencrypt.status.io/ for more details.
2021-07-19 11:13:57 ERROR (SyncWorker_7) [hass_nabucasa.acme] Can't register to ACME server: urn:ietf:params:acme:error:badPublicKey :: The JWS was signed by a public key the server does not support :: sa.StorageAuthority.KeyBlocked timed out after 5000 ms
2021-07-19 11:14:08 ERROR (SyncWorker_7) [hass_nabucasa.acme] Can't connect to ACME server: urn:acme:error:serverInternal :: The server experienced an internal error :: The service is down for maintenance or had an internal error. Check https://letsencrypt.status.io/ for more details.
2021-07-19 11:14:24 ERROR (SyncWorker_8) [hass_nabucasa.acme] Can't register to ACME server: urn:ietf:params:acme:error:badPublicKey :: The JWS was signed by a public key the server does not support :: sa.StorageAuthority.KeyBlocked timed out after 5000 ms
2021-07-19 11:14:35 ERROR (SyncWorker_3) [hass_nabucasa.acme] Can't connect to ACME server: urn:acme:error:serverInternal :: The server experienced an internal error :: The service is down for maintenance or had an internal error. Check https://letsencrypt.status.io/ for more details.
2021-07-19 11:14:51 ERROR (SyncWorker_3) [hass_nabucasa.acme] Can't register to ACME server: urn:ietf:params:acme:error:badPublicKey :: The JWS was signed by a public key the server does not support :: sa.StorageAuthority.KeyBlocked timed out after 5000 ms
2021-07-19 11:15:02 ERROR (SyncWorker_3) [hass_nabucasa.acme] Can't connect to ACME server: urn:acme:error:serverInternal :: The server experienced an internal error :: The service is down for maintenance or had an internal error. Check https://letsencrypt.status.io/ for more details.
2021-07-19 11:15:18 ERROR (SyncWorker_1) [hass_nabucasa.acme] Can't register to ACME server: urn:ietf:params:acme:error:badPublicKey :: The JWS was signed by a public key the server does not support :: sa.StorageAuthority.KeyBlocked timed out after 5000 ms
I tried stopping HA, renaming the .cloud
to something else, then start HA again (allowing the system to recreate that folder and respective contents). I also tried logging out and back into nabu casa.
However, the errors still happen over and over again. I couldn’t find any information on this. Does anyone know what’s going on?
Thanks in advance!
