Hass NFC - Control Home Assistant with NFC tags
Hi Gerben - the app settings/scrolling update works great! I tested both the normal high res mode as well as the reduced res in power savings mode that gave me the trouble before. It’s much easier to read the help at the bottom now.
I do have a few suggestions for further improvement.
  • Replace the 8 lines of long lived token with a single line “********” to obscure it after a save. If the api password is also in clear text after a save, obscure it too.
  • The screenshots on Google Play should be updated to reflect the current Hass NFC screens. Since there is limited info on GP on how the app works, these screens are invaluable to show what can be done.
  • Expand the help in the app a bit more - such as describe the notification options. (only vibration was obvious to me)
  • Suggest renaming “toast notification” to “popup notification” instead.
  • Describe in help how to create a long lived token or point to the HA Authentication how to.
Thanks!
Thanks for all the suggestions! I think I can make the token and password fields of the type ‘password’ which should make content hidden.
Good point on the screenshots. I’ll have a look on updating them!
The settings can also have a little more explanations added.
Didn’t I add information about the tokens somewhere? I thought I added that, but not sure, but indeed a good idea in simple steps to add that!
How are you guys liking the dark theme btw? :slight_smile:
Good suggestions indeed about hiding the token…
Well, dark theme … I never need the app , once the NFC are ready … :wink:
Hi Gerben, thanks again for all your great support for this app! I was mainly pointing out the little things that tripped me up to make it better for any new users that come along.
I agree with fabio that the dark theme wasn’t all that interesting for an app that runs hidden/in the background 99% of the time. Hey, I was just thrilled to be able to hit “SAVE”! :smile:
Bought it! This works great ib my samsung s8. Any chance this can get released for android 4.4? I have a few samsung s3 I’d like to use it on!
Screenshot_2019-03-12-06-54-13|281x500
Cheers. I believe there was a reason I couldn’t release on there, but I’ll have another look to see if it’s possible.
On a sidenote, I used to have a S3 for some dev fun, and it ran LineageOS with Android 7.1 I believe. Ran a lot smoother and faster than the bloated default 4.4 release. So that would be an option in case I run into limitations, but I’ll let you know when I get some time to check.
Your screenshot doesn’t seem to load for me?
@GaryOkie I’ve updated the store images like you suggested, thanks again. Will work on your other suggestions soon. :slight_smile:
It was a screen cap of my about screen with versions if you need it.
I’ve had bad experiences with rooting/ flashing in the past. Maybe it’s time to revisit.
Thx
I’ve just uploaded 1.1.5 in the Play Store. This version plays a sound for both a successful and a failed scan. You can enable it in the settings. The app should also be working on Android 4.4 and higher now. Please keep in mind that the fingerprint mechanism only works from Android 6 and higher. The token and password fields are also no longer readable in settings now.
@tsimons78 I was wondering if you had the chance to try it out on your S3 devices. Let me know if it works :slight_smile:
Would be great if you guys could leave a nice rating/review in the store! :slight_smile:
Very good idea @Gerben321.
I just purchased the app, unfortunately, all the tags I have are not writable.
Is there a way to associate the action with a non writable tag?
thanks.
Thanks. Ah that’s too bad! It’s on my list to do actually. An action based on the id of the tag. So you save the data on your phone.
I’ll have to investigate this further. :slight_smile:
Nice!
Looking forward to seeing it in the close future :wink:
I see it, but my S3 is on my “house’s” google account, so I’d have to rebuy it. Before I do that I will swap out the S3 back to my account…
Any chance you can make this app work with Google Family? If my setup works, I’ll end up having to buy it 3 times for 2 people (me, wife, house). …I’ll buy it the second time on the family
https://support.google.com/googleplay/answer/7007852?hl=en
There’s no option for me to enable/disable that as far as I can see. When I check the store I see it is available for Google Family if it’s bought after 2016. Are you sure your account is coupled to your Family account? Isn’t there a limit or something to it? Not familiar with it.
Is anyone having a problem with their tags? I’m still in a testing phase, so I’m not sure if my problem correlates with the new version 1.1.5. I’m using a Samsung S8 running 8.0.0, it got a security update from Verizon on 3/5
When I scan a tag, I get the android popup “Couldn’t read payload”. I tried re-writing my tag, I tried writing to another tag, same problem.
ScreenCap: Couldn’t read payload
using “NFC Tools” (from Play store) I can read the tag
Screen Cap:NFC Tools
Thanks,
~Todd
That’s odd. Which write option did you use? Your service is invalid. It should contain much more data. Are all the dropdowns working and filled with data?
I haven’t changed anything in the writing or reading part of the app for a long time, so I don’t think a recent update have caused that.
I got my google family straightened out, got it on the wife’s S7 and it has the same problem.
will play more later…
I’ve identified my problem. I forgot that I switched from an Advanced Write to toggle a switch to an Advanced Write to fire a script (which gives me more flexibility on the software side without many re-writes, etc.)
When configured for the script domain, and the script (I matched up the ID#), I get the payload problem. When I switched back to a normal “Write”, it resolved the ID to the name of the script and it works fine.
I noticed the payloads are written differently:
Write:
{"loadScript":"<scriptID>","auth":"0"}
Advanced Write:
{"domain":"script","service":"<scriptID>","auth":"0"}
Maybe hide the script domain on Advanced Write? or have it write as loadScript?
Thanks again!
I just noticed an Oddity with my Samsung S3 on Android 4.4
It told me EMTPY tag when the tag is written by my S8. I re-wrote it on the S3 and it works on both. Using NFC Tasks from the play store I looked that the payloads, seems the order of the payloads makes a difference
S8 Tag: {"loadScript":"<scriptID>","auth":"0"} Works on S8 and S7, NOT S3
S3 Tag: {"auth":"0","loadScript":"<scriptID>"} Works on S3, S7 and S8
I then tried to recreate the problem with a different tag to be sure, I wrote the tag on my S8 (loadScript as the first token) and it works on all.
Does Hass NFC write out a debug log onto the phone that I can grab?
Thanks again.
Are nfc tags with 144 bytes enough?
