I’ve installed HASS on a Raspberry Pi using the instructions for NGINX with subdomain on the instruction page.
My NGINX configuration is as follows:
server {
listen 80;
server_name sub.domain.tld;
return 301 https://$server_name$request_uri;
client_max_body_size 25M;
server {
listen 443 ssl;
ssl on;
ssl_certificate /etc/letsencrypt/live/sub.domain.tld/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/sub.domain.tld/privkey.pem;
ssl_session_cache shared:SSL:10m;
ssl_protocols TLSv1.1 TLSv1.2;
ssl_ciphers 'EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH';
ssl_prefer_server_ciphers on;
ssl_dhparam /etc/ssl/certs/dhparam.pem;
# add_header Strict-Transport-Security "max-age=31536000; includeSubDomains" always;
proxy_buffering off;
location / {
proxy_pass http://127.0.0.1:8123;
proxy_set_header X-Real-IP $210.54.37.134;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
# WebSocket support (nginx 1.4)
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
# location ^~/api/websocket/ {
# proxy_pass http://127.0.0.1:8123;
My HASS config is as follows:
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: !secret lat
longitude: !secret long
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Pacific/Auckland
# Show links to resources in log and frontend
# introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
# Uncomment this to add a password (recommended!)
api_password: !secret api_pass
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# base_url: sub.domain.tld
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Track the sun
sun:
# Weather prediction
- platform: yr
# Text to speech
tts:
- platform: google
group: !include groups.yaml
Everything installed properly with no problem, however once I set up the certificate after the installation, I get the following error when logging in:
WebSocket connection to 'wss://sub.domain.tld/api/websocket' failed: Error during WebSocket handshake: Unexpected response code: 301
It’s been reported as an issue on reddit as well by others. I’ve tried Firefox, Chrome and Edge, all in incognito mode, both on my network, and on a separate network using a different machine (laptop). It’s definitely not a DNS or router issue as someone tried to suggest on reddit.
Any help would be greatly appreciated with this, or if I should open an issue on github let me know.
HASS Version: 0.50.2
Python version: 3.4.2
NGINX Version: 1.6.2
