Hi, I started an update, but after that, the HASS is not booting.
The HASS is on SD card in RPi and I’m using Linux on my PC.
I could not find any general recovery steps.
$ ping 192.168.42.42
PING 192.168.42.42 (192.168.42.42) 56(84) bytes of data.
From 192.168.42.42 icmp_seq=1 Destination Host Unreachable
I was updating everything, the OS, the core, and add-ons.
How do I hook up a monitor to RPi? There is no HDMI, DP, or anything…
I will have to read about copying backups …
Nevertheless, I’m slowly losing faith in a system that destroys itself with an update - this is even worse than M$ Windoze - that will only crash at worst…
Ok, I got the cable and it says “Bad cluster number 0 … Firmware not Found” Seriously, how bad a system has to be to fuckup itself with an update?!
BTW the SD card can be still read in a reader connected to the computer.
I also read some opinions that the SD card might be the issue - old, bad blocks, etc… Pass completed, 0 bad blocks found. (0/0/0 errors)
I don’t know, is 0 bad blocks enough to blame the SD card?
Assuming you connected it to a windows computer to test it might have skipped the Linux partitions. So I would certainly be suspecting the SD card is faulty.
Nothing to do with the update if your card is failing. e.g. A database write could eventually cause the same thing.
Also please watch your language. This is an all ages forum.
I also hate it when you pay that much for a piece of software and those programmers who make themselves rich by just tapping on a keyboard don’t do their work…
