I am looking to setup a NAS so that I have a common place to save images acquired by my security cameras etc. I found a couple of guides for setting up a Pi as a NAS (network attached storage). I want to do this on the Pi I use to run HA, but I don’t want a solution which interrupts HA. What have people tried and recommend?
Cheers
IMHO don’t use a PI as NAS it is really slow because everything goes on the USB-Pipe. Read / Write is just horrendous in my opinion. Better way would be to mount a “real” NAS solution via SMB / NFS.
But if you really wanna do it I can’t think of a reason why not. A friend of mine is using his synology to run HA.
~Cheers
I suppose I could also set up my 2 Tb Time capsule as a NAS - then point my pi zero to that to save images which could be accessed by HA on another pi…? Perhaps I am overcomplicating this!
That sounds perfectly reasonable to me…save from one point onto NAS, access from another…that’s what a NAS is mostly about
~Cheers
OpenMediaVault for Raspberry Pi + Home Assistant.
Can i run OpenMediaVault + Home Assistant.on the same Raspberry Pi?
Yes, I checked it.
I have several home built NAS and tried OMV on a Pi with mirrored disks. Didn’t work well at all. You can run a NAS off a Pi for file sharing but I think every geek I ever ran into once they figured out they could run media servers and stuff off of NAS they usually do. You can build a pretty great NAS for next to nothing on a micro ATX board and inexpensive chip.
Just my opinion. I’ve run NAS on pi several times and found it not that great of an experience.
installing in the dockers?
Nope. I flashed Openmediavault image for RPi 2, and then installed Home Assistant in a virtual environment (virtualenv).
tonight I will try this system on an old motherboard mini-itx that I home equipped with intel atom n270, 2 gb ram and 1 tb hd sata
I agree, Pi is really slow for use as NAS and streaming media
can you say how slow exactly? I use my wifi router as Nas and read//write is 2,5 MByte max. Do you think a RPI3 could perform better?
