Hass stopped working in the middle of the night
in the middle of the night I noticed that hass stopped working. The frontend was still up, but i could not turn on off any light. In the morning i saw then there is a update avaible.
can it be that the update stopped hass somehow even before i decided to push the upgrade button?
Did you find out, what was wrong?
I have the same problem, except I can’t reach the frontend. Every now and then, my HA stops working.
At first I thought that it was the internet connection. But it won’t run the automations either.
I have to turn off/on the power, to get it to work again.
Here is my Supervisor Log, but I don’t understand it. Is there another log?
I run HassIO with Home Assistant 0.62.1 on a Raspberry Pi 3.
07:49:42 is where I had it rebooted.
starting version 3.2.4
18-02-05 05:04:30 INFO (MainThread) [__main__] Initialize Hassio setup
18-02-05 05:04:30 INFO (MainThread) [__main__] Setup HassIO
18-02-05 05:04:30 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to supervisor homeassistant/armhf-hassio-supervisor with version 0.85
18-02-05 05:04:30 INFO (MainThread) [hassio.misc.host_control] Send 'info' to HostControl.
18-02-05 05:04:32 INFO (MainThread) [hassio.misc.host_control] Receive from HostControl: { "type": "resinos", "version": "1.1", "last_version": "1.1", "hostname": "hassio", "features": ["shutdown", "reboot", "update", "hostname"], "os": "GNU/Linux" }.
18-02-05 05:04:32 INFO (SyncWorker_1) [hassio.docker.interface] Attach to image homeassistant/raspberrypi3-homeassistant with version 0.62.1
18-02-05 05:04:32 WARNING (MainThread) [hassio.addons.data] Can't read repository information from /data/addons/git/1f9f3b7a/repository.json
18-02-05 05:04:32 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/git/1f9f3b7a repository
18-02-05 05:04:32 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/core repository
18-02-05 05:04:32 INFO (MainThread) [hassio.addons] Load addons: 19 all - 19 new - 0 remove
18-02-05 05:04:32 INFO (SyncWorker_1) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-ssh with version 3.0
18-02-05 05:04:32 INFO (SyncWorker_7) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-samba with version 3.0
18-02-05 05:04:32 INFO (SyncWorker_2) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-duckdns with version 1.0
18-02-05 05:04:32 INFO (SyncWorker_3) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-tellstick with version 0.4
18-02-05 05:04:32 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
18-02-05 05:04:33 INFO (MainThread) [hassio.snapshots] Found 3 snapshot files
18-02-05 05:04:33 INFO (MainThread) [hassio.addons] Startup initialize run 0 addons
18-02-05 05:04:33 INFO (MainThread) [__main__] Run HassIO
18-02-05 05:04:33 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
18-02-05 05:04:33 INFO (MainThread) [hassio.core] Ignore Hass.io auto updates on beta mode
18-02-05 05:04:33 INFO (MainThread) [hassio.core] Start API on 172.30.32.2
18-02-05 05:04:33 INFO (MainThread) [hassio.addons] Startup system run 1 addons
18-02-05 05:04:33 INFO (SyncWorker_0) [hassio.docker.interface] Clean homeassistant/armhf-addon-tellstick docker application
18-02-05 05:04:35 INFO (SyncWorker_0) [hassio.docker.addon] Start docker addon homeassistant/armhf-addon-tellstick with version 0.4
18-02-05 07:49:42 INFO (MainThread) [hassio.addons] Startup services run 3 addons
Oh yes sorry…I found it.
it’s z-wave healing. Turn it off and the issue is gone. When it was on I needed to restart HA, since at 2 Clock in the Morning the CPU stayed at 30% and the whole system lagged so terrible that nothing worked anymore.
after disabling z-wave autoheal the system is up and running since two month stable now.
