Trying to do the latest update from 0.43.1 to latest via pip3 install --upgrade homeassistant
I’m getting it failing (rebooted and tried several times)
here’s the errors
Exception:
File "/usr/lib/python3/dist-packages/pip/basecommand.py", line 122, in main
status = self.run(options, args)
File "/usr/lib/python3/dist-packages/pip/commands/install.py", line 295, in run
requirement_set.install(install_options, global_options, root=options.root_path)
File "/usr/lib/python3/dist-packages/pip/req.py", line 1436, in install
requirement.install(install_options, global_options, *args, **kwargs)
File "/usr/lib/python3/dist-packages/pip/req.py", line 672, in install
self.move_wheel_files(self.source_dir, root=root)
File "/usr/lib/python3/dist-packages/pip/req.py", line 902, in move_wheel_files
pycompile=self.pycompile,
File "/usr/lib/python3/dist-packages/pip/wheel.py", line 214, in move_wheel_files
clobber(source, lib_dir, True)
File "/usr/lib/python3/dist-packages/pip/wheel.py", line 204, in clobber
os.makedirs(destdir)
File "/usr/lib/python3.4/os.py", line 237, in makedirs
mkdir(name, mode)
PermissionError: [Errno 13] Permission denied: '/usr/local/lib/python3.4/dist-packages/homeassistant'
Storing debug log for failure in /home/homeassistant/.pip/pip.log
Can anyone offer any help? or shall I do a fresh install
homeassistant@hassbian:/home/pi $ source /srv/homeassistant/homeassistant_venv/bin/activate
bash: /srv/homeassistant/homeassistant_venv/bin/activate: No such file or directory
As taken from the Hassbian upgrade guide
Change to virtual enviroment source /srv/homeassistant/homeassistant_venv/bin/activate
Login to Raspberry Pi ssh pi@your_raspberry_pi_ip
Change to homeassistant user sudo su -s /bin/bash homeassistant
Update HA pip3 install --upgrade homeassistant
Type exit to logout the hass user and return to the pi user.
Collecting yarl<0.11,>=0.10.0 (from aiohttp==2.0.7->homeassistant)
Using cached yarl-0.10.2.tar.gz
Requirement already up-to-date: MarkupSafe>=0.23 in /srv/homeassistant/lib/python3.4/site-packages (from jinja2>=2.9.5->homeassistant)
Installing collected packages: requests, homeassistant, multidict, yarl
Found existing installation: requests 2.14.1
Uninstalling requests-2.14.1:
Successfully uninstalled requests-2.14.1
Found existing installation: homeassistant 0.43.2
Uninstalling homeassistant-0.43.2:
Successfully uninstalled homeassistant-0.43.2
Rolling back uninstall of homeassistant
Exception:
File "/srv/homeassistant/lib/python3.4/site-packages/pip/basecommand.py", line 215, in main status = self.run(options, args)
File "/srv/homeassistant/lib/python3.4/site-packages/pip/commands/install.py", line 342, in prefix=options.prefix_path,
File "/srv/homeassistant/lib/python3.4/site-packages/pip/req/req_set.py", line 784, in **kwargs
File "/srv/homeassistant/lib/python3.4/site-packages/pip/req/req_install.py", line 851, in self.move_wheel_files(self.source_dir, root=root, prefix=prefix)
File "/srv/homeassistant/lib/python3.4/site-packages/pip/req/req_install.py", line 1064, in isolated=self.isolated,
File "/srv/homeassistant/lib/python3.4/site-packages/pip/wheel.py", line 345, in clobber(source, lib_dir, True)
File "/srv/homeassistant/lib/python3.4/site-packages/pip/wheel.py", line 329, in os.utime(destfile, (st.st_atime, st.st_mtime))
PermissionError: [Errno 1] Operation not permitted
