HASS Version 2024.10 Kostal Plenticore not work
versuche per HACS die Kostal Plenticore Integration einzubinden.
Daher habe ich es in HACS runter geladen. Finde die Dateien auch in dem Ordner homeassistant/config/custom_components/kostal_plenticore/
Nun beim einbinden der Integration erhalte ich den Fehler:
Du kannst diese Integration hinzufügen, indem du sie zu deiner „configuration.yaml“ hinzufügst. Weitere Informationen findest du in der Dokumentation.
Daher habe in wie in der Doku angegeben in der homeassistant/config/configuration.yaml
folgendes mit aufgenommen
    - platform: kostal_plenticore
      host: 192.168.178.xx
      password: 'SecretPW'
      dc_inputs: 2 # Optional, default: 2, valid values: 1, 2, 3
      scan_interval: 30 # Optional, default: 30
      monitored_conditions:
        - BatteryPercent
        - BatteryCycles
        - BatteryPower
        - HomeGridPower
        - HomeOwnPower
        - HomePVPower
        - HomeBatteryPower
        - GridPower
        - DCPower
        - PVPower
        - AutarkyDay
        - AutarkyMonth
        - AutarkyTotal
        - AutarkyYear
        - CO2SavingDay
        - CO2SavingMonth
        - CO2SavingTotal
        - CO2SavingYear
        - PV1Power
        - PV1Voltage
        - PV1Current
        - PV2Power
        - PV2Voltage
        - PV2Current
        - PV3Power
        - PV3Voltage
        - PV3Current
        - ACFrequency
        - ACL1Current
        - ACL1Power
        - ACL1Voltage
        - ACL2Current
        - ACL2Power
        - ACL2Voltage
        - ACL3Current
        - ACL3Power
        - ACL3Voltage
        - HomeConsumptionDay
        - HomeConsumptionMonth
        - HomeConsumptionTotal
        - HomeConsumptionYear
        - HomeConsumptionFromBatDay
        - HomeConsumptionFromBatMonth
        - HomeConsumptionFromBatTotal
        - HomeConsumptionFromBatYear
        - HomeConsumptionFromGridDay
        - HomeConsumptionFromGridMonth
        - HomeConsumptionFromGridTotal
        - HomeConsumptionFromGridYear
        - HomeConsumptionFromPVDay
        - HomeConsumptionFromPVMonth
        - HomeConsumptionFromPVTotal
        - HomeConsumptionFromPVYear
        - HomeConsumptionYieldDay
        - HomeConsumptionYieldMonth
        - HomeConsumptionYieldTotal
        - HomeConsumptionYieldYear
        - OwnConsumptionRateDay
        - OwnConsumptionRateMonth
        - OwnConsumptionRateTotal
        - OwnConsumptionRateYear
        - MinSoC
        - SmartBatteryControl
        - InverterState
        - LimitEvuAbs
        - SerialNumber
        - ArticleNumber
        - ProductName
Leider zeigt es mir aber keine Sensor Daten an.
Jemand nen Tipp?
Danke
Greetings Michi,
Please read the FAQ before posting. This is an English only forum.
Please translate the original for us or risk that this POST will be closed.
How to help us help you - or How to ask a good question.
Bitte lesen Sie die FAQ, bevor Sie einen Beitrag posten. Dies ist ein ausschließlich englischsprachiges Forum.
Bitte übersetzen Sie das Original für uns, sonst besteht die Gefahr, dass dieser BEITRAG geschlossen wird.
