I just tried installing Home Assistant for the first time on my Raspberry Pi 4.
After flashing the Micro SD with HAOS 9.4 from here for Raspberry 4 64 bit and starting the machine up, it won’t connect to the router. I checked the router and it doesn’t get an IP. The green light flashes irregularly, indication it’s doing something. To check the card, I flashed Raspberry OS on it which works flawlessly.
I tried both the 32-bit and 64-bit variant. I also tried the previous version, 9.3. I tried a different MicroSD card. In all cases the same result: The lights are coming on, but the device doesn’t get an IP. I’m not sure if it’s doing anything at all.
Any hints?
