Hello, newbie here installing onto a working RP as per Home Assistant Core instructions (Raspberry Pi - Home Assistant). I have followed all the instructions and all seems well. However, when I try to start Hass, an error occurs and the launch is aborted
from jinja2 import contextfilter, contextfunction
ImportError: cannot import name ‘contextfilter’ from ‘jinja2’ (/srv/homeassistant/lib/python3.7/site-packages/jinja2/init.py)
Please advise how I should proceed. The Pi is currently successfully running Pihole and with the shortage I only have this board available.
I have made progress with this issue. To aid others who may be experiencing issues such as this, I have progressed by:
Upgrade Python to 3.9.x . I used 3.9.1 (beware I still have issues, so maybe other versions will be better. Also note that the devs warn that a lot of these upgrades are not officially supported)
Following the upgrade of Python I had issues with the Sqlite3 version, so used the advice given by @CollinRobbins here. I also installed the libffi7 with instructions given by @torkishere.
The installation now launches, and I am able to access and configure it via browser. I have stability issues and I’m having trouble with the autostart, but I am hopeful I’ll find my way.
Thankyou for comments to this thread and to the those posting generous advice on the forums
