Im setting up my home assistant for the first time on a raspberry pi 3 following the tutorials by BRUH Automation.
i got home assistant running, and also followed the tutorial for duckdns and letsencrypt.
Duckdns is working I can see my hass on example.duckdns.org:443
but as soon as i add these lines to the configuration.yaml (with “yourdomain” of course changed)
I’m having the exact same issue. What happened to the files inside the letsencrypt folder? I have had my setup working on TLS for 4 days, now it has broken by itself.
I’m facing the same problem and I tried to delete the letsencrypt folder and download the certificates again.
Bus as soon as I add those lines to my configuration.yaml HA won’t start up.
Any idea how I can fix this??
