How can i extend the range of Zigbee signals for Home Assistant Yellow?
Add some routers
Amazing work indeed. Will refer to it for my case and follow tge recommendations.
My point is can i add any routers or i should look for something specific for compatibility?
Yes, @Hedda has done a great job with the guide! ![]()
While all Zigbee Router devices should work in theory the reality is that some work better or worse than others. That fact is covered in that community guide, as well as some specific recommend products that are ”known good” Zigbee Router devices. As well be aware that almost all mains-powered are also act as Zigbee Router devices, however they usually do not work as as dedicated Zigbee Router devices, but you can compensate by adding more of them. Noted it that guide is that some products that also act as Zigbee Router devices are known to not work at all or work badly with some Chinese Zigbee devices like those made by Aqara, Tuya, and Xiaomi. Again read and follow → Zigbee networks: how to guide for avoiding interference + optimizing using Zigbee Router devices (repeaters/extenders) to get best possible range and coverage
Got it. Thank you for the help.
