Hello.
After upgrading my Home Assistant to 0.64.0 or 0.64.1 (Hassbian installation), checking the configuration as explained here, doesn’t seem to yield the previous result.
In 0.63.3:
Testing configuration at /home/homeassistant/.homeassistant
2018-02-27 22:08:42 INFO (MainThread) [homeassistant.setup] Setting up mqtt
2018-02-27 22:08:42 INFO (MainThread) [homeassistant.setup] Setting up recorder
2018-02-27 22:08:42 INFO (MainThread) [homeassistant.setup] Setting up logger
2018-02-27 22:08:42 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt took 0.1 seconds.
2018-02-27 22:08:42 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.1 seconds.
2018-02-27 22:08:42 INFO (MainThread) [homeassistant.setup] Setup of domain logger took 0.1 seconds.
2018-02-27 22:08:42 INFO (MainThread) [homeassistant.setup] Setting up http
2018-02-27 22:08:42 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2018-02-27 22:08:42 INFO (MainThread) [homeassistant.setup] Setting up history
2018-02-27 22:08:42 INFO (MainThread) [homeassistant.setup] Setting up system_log
2018-02-27 22:08:42 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2018-02-27 22:08:42 INFO (MainThread) [homeassistant.setup] Setting up api
2018-02-27 22:08:42 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2018-02-27 22:08:42 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2018-02-27 22:08:42 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2018-02-27 22:08:42 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds.
2018-02-27 22:08:42 INFO (MainThread) [homeassistant.setup] Setting up frontend
2018-02-27 22:08:42 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.
2018-02-27 22:08:43 INFO (MainThread) [homeassistant.setup] Setting up input_text
2018-02-27 22:08:43 INFO (MainThread) [homeassistant.setup] Setting up alert
2018-02-27 22:08:46 INFO (MainThread) [homeassistant.setup] Setting up sensor
2018-02-27 22:08:46 INFO (MainThread) [homeassistant.setup] Setting up sun
2018-02-27 22:08:46 INFO (MainThread) [homeassistant.setup] Setting up notify
2018-02-27 22:08:46 INFO (MainThread) [homeassistant.setup] Setting up binary_sensor
2018-02-27 22:08:46 INFO (MainThread) [homeassistant.setup] Setting up ffmpeg
2018-02-27 22:08:46 INFO (MainThread) [homeassistant.setup] Setting up input_number
2018-02-27 22:08:46 INFO (MainThread) [homeassistant.setup] Setting up alarm_control_panel
2018-02-27 22:08:46 INFO (MainThread) [homeassistant.setup] Setting up climate
2018-02-27 22:08:46 INFO (MainThread) [homeassistant.setup] Setting up input_select
2018-02-27 22:08:46 INFO (MainThread) [homeassistant.setup] Setting up xiaomi_aqara
2018-02-27 22:08:46 INFO (MainThread) [homeassistant.setup] Setting up input_boolean
2018-02-27 22:08:46 INFO (MainThread) [homeassistant.setup] Setting up group
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setting up duckdns
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setting up shell_command
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setting up weblink
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setting up discovery
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain input_text took 5.5 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain alert took 5.5 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 1.8 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 1.8 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 1.8 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain binary_sensor took 1.8 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain ffmpeg took 1.8 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain input_number took 1.8 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain alarm_control_panel took 1.8 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain climate took 1.8 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain input_select took 1.7 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain xiaomi_aqara took 1.7 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain input_boolean took 1.7 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain group took 1.7 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setting up zone
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain duckdns took 0.0 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain shell_command took 0.0 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setting up logbook
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setting up config
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setting up media_player
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setting up camera
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setting up customizer
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setting up history_graph
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain weblink took 0.0 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain discovery took 0.0 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 0.0 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.0 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain media_player took 0.0 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain camera took 0.0 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setting up script
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setting up light
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setting up cover
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setting up switch
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setting up automation
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain customizer took 0.0 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain history_graph took 0.0 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 0.0 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain light took 0.0 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain cover took 0.0 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain switch took 0.0 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setting up device_tracker
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain device_tracker took 0.0 seconds.
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setting up ios
2018-02-27 22:08:48 INFO (MainThread) [homeassistant.setup] Setup of domain ios took 0.0 seconds.
In 0.64.x:
As I’ve noticed that there were a couple of commits in 0.64.x, I was wondering if anyone knows if this is a change in behavior (only show errors) or if it is a regression introduced.
Thanks in advance for sharing your insights.
