HASSbian 1.23 - Pre-release
Good morning.
Just wanted to highlight that there’s a pre -release of HASSbian.
In the previous release there was a minor change with the symlinks used for Open Z-Wave and OZWCP.
I updated the links but didn’t test OZWCP properly and a new minor bug crept in.
This has since been fixed.
That’s all for this minor release.
Release can be found here and assuming nothing big jumps out it will be live tonight.
Is there a way to fix this minor bug without having to download and reinstall from HASSbian 1.22?
You can create the symlink manually after the hassbian-config install openzwave script has been run.
As the pi user run the following.
cd /srv/homeassistant/src/open-zwave-control-panel
sudo ln -s /srv/homeassistant/lib/python3.*/site-packages/python_openzwave/ozw_config config
