I´ve started with Home Assistant about 3 weeks ago, starting with Hass.IO where I had to deal a lot with the docker/container concept. I finally managed it to administrate but I do prefer a “real” linux. So I downloaded Hassbian 1.31 and also update to HA 0.59.1 yesterday.
The first impression so far is good, sometimes a bit confusing but it becomes clearer with every step. Before that I used domoticz - some things were better there, some worse. All in all I think I´ll stick to HA now.
Since I run some Z-Wave devices I am also using the built-in Z-Wave manager. Although it is pretty comfortable to configure everything in one GUI I am not really happy with it:
- If I make changes, e.g. node associations or parameter it is not updating it´s screen. Even after logoff/logon still the old settings are shown in the GUI.
- the OZW log part is difficult to read, everytime I´ve to choose the lines which I would like to see, otherwise the whole (long) log is appearing
- all in all it seems like a good development to integrate it in HA but it seems more basic (until now)…
So I would like to use OZWCP in parallel. However I found a lot of howto to activate/install it but they are not Hassbian specific or for older versions. Is it correct that OZWCP was part of hassbian-config? If I am right, it can be only installed by compile it from the original github repository (https://github.com/OpenZWave/open-zwave-control-panel) directly. Or are there any other maybe easier methods?
Has somebody already done this and can give me some hints and tips how to install?
Thanks.
