I just finished installing the latest hassbian which includes support for Open Zwave devices. And true, I have a GE switch which was detected right away. But I own a Aeotec Minimote which I assume you cannot configure it through Home Assistant. Rather you need OZWCP. So my questions are the following:
is OZWCP pre installed in the latest hassbian or do I need to install it?
If already installed, where it it. Or if I need to install it, what is the recommended guide?
@benquan you should not need OZWCP to set up the Minimote. You can add it through the ZWave menu in HASS and change to scene mode from the ZWave section of the Configuration menu. Leave out OZWCP as it is totally unnecessary on all but the most obscure settings. Installing Hasbian and then Zwave with the PIP option is far quicker and long term less messy.
