HASSbian Devices show up, but do not work
I used to have the All-In-One installer set up, but mysteriously it stopped working.
I installed HASSbian and tried to connect my mFi equipment and it shows up on the homeassistant, but when i try to toggle a switch, it does not work.
How can I fix this? There is no error showing up on the logs and the home assistant knows when I externally toggle the devices using the mFi app.
I reinstalled Home Assistant the traditional route and it worked.
