Any chance there is one out there for Vmware?
There is an x86 version now. Im currently using this fine, was just curious if an hassbian was out there, I would have thought as active as this place is it would be out there:)
As was said, Hassbian is for the Raspberry Pi, the description is a Raspberry Pi image with Home Assistant built-in. There are many other options for installing if you want to run it in a VM, including a manual install in a Python virtual environment (or even without a virtual environment)
as was said, I’m using ha in a vm today. I was curious about a hassbian image. not for me.
