Hassbian not showing Plex Server
Hi all,
I am new - just joined :slight_smile:
After setting up the RPI3 with Hassbian and start it - saw that it recognized my PLEX server and wanted me to give a Token and SSL (true or false) with Verification - I have followed instructions and put all it needs:
The token that I got from the end URL where it says token= and I put off on SSL and False on verifications.
For a few seconds I saw the PLEX there but after I restart the Server it was gone!! :frowning:
I would be happy to know why?
I have checked the plex.conf file and everything there looks OK - Even changed them a bit from on to off and false with true… restarting the service using sudo each and every time I made a change - with no luck.
I have added
media_player:
- platform: plex
to configuration.yaml - still nothing…
What happened to my Plex? where did it go?
Please assist me to understand what went wrong.
As I have mentioned I am a beginner with hassbian and home assistant.
After I delete the plex.conf file and restart the service - I can see the PLEX back again - But it needs to be configured the same as it was to start with - token, SSL and verification - I can’t do nothing with it right now.
Arye
Did you ever get this sorted @Agiliot I also have the same problem but never used to on earlier installs of HASSBIAN.
I have exactly the same symptoms, RPi3, HASSBIAN etc
