Just got a new laptop with Windows 10 pro and I can’t get the home assistant Samba share to connect. I’m running Hassbian on a RPI3. Works fine on my Windows 7 computers.
windows gives me Error code: 0x80004005
I’ve googled around and have tried several things but the issue persists. I have to imagine others have had trouble with this and have a solution.
I used bruh’s instruction on setting up samba, but I couldn’t access the share after Ubuntu 17.10. I run development versions, so being able to access the samba share on my Hassbian setup is important. I had to add the following line to the global section of /etc/samba/smb.conf on the client to gain clickable access.
I’ve tried enabling SMB 1.0/CIFS File Sharing Support in Windows Control Panel (I don’t think this is a preferred solution anyways for security reasons) - It did not work.
I’ve tried setting client min/max protocol = SMB2 and SMB3
I’ve tried turning off guest mode
I’ll try setting max protocol to NT1 that’s the first time seeing this option.
I recently came back to this as I’m switching over to HASS.io. I was able to resolve it:
You need to enable SMB 1.0/CIFS file sharing in the control panel, but you also have to disable guest mode AND provide username/password credentials. By default the samba add on in HASS.io has guest mode set to true.
