Hi all,
I tried to install FFmpeg to get my Wifi camera stream working:
but it fail all my HA after I followed the Troubleshooting on the stream page as:
HA now fail at the start after MQTT with those errors…
2019-09-25 12:10:02 INFO (MainThread) [homeassistant.components.switch] Setting up switch.mqtt
File "/srv/homeassistant/bin/hass", line 10, in <module>
sys.exit(main())
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/__main__.py ", line 401, in main
exit_code = asyncio_run(setup_and_run_hass(config_dir, args))
File "/usr/lib/python3.7/asyncio/runners.py", line 43, in run
return loop.run_until_complete(main)
File "/usr/lib/python3.7/asyncio/base_events.py", line 584, in run_until_compl ete
Exception in thread Thread-1:
File "/usr/lib/python3.7/threading.py", line 917, in _bootstrap_inner
self.run()
File "/usr/lib/python3.7/threading.py", line 865, in run
self._target(*self._args, **self._kwargs)
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/util/loggin g.py", line 86, in _process
record = run_coroutine_threadsafe(self._queue.get(), self.loop).result()
File "/usr/lib/python3.7/concurrent/futures/_base.py", line 430, in result
raise CancelledError()
concurrent.futures._base.CancelledError
return future.result()
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/setup.py", line 46, in async_setup_component
return await setup_tasks[domain] # type: ignore
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/setup.py", line 52, in async_setup_component
return await task # type: ignore
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/setup.py", line 131, in _async_setup_component
await async_process_deps_reqs(hass, config, integration)
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/setup.py", line 282, in async_process_deps_reqs
hass, config, integration.domain, integration.dependencies
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/setup.py", line 75, in _async_process_dependencies
results = await asyncio.gather(*tasks)
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/__main__.py ", line 304, in setup_and_run_hass
log_no_color=args.log_no_color,
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/bootstrap.p y", line 150, in async_from_config_file
config_dict, hass, enable_log=False, skip_pip=skip_pip
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/bootstrap.p y", line 95, in async_from_config_dict
await _async_set_up_integrations(hass, config)
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/bootstrap.p y", line 376, in _async_set_up_integrations
*(async_setup_component(hass, domain, config) for domain in domains_to_load)
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/setup.py", line 288, in async_process_deps_reqs
hass, integration.domain, integration.requirements
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/requirement s.py", line 68, in async_process_requirements
ret = await hass.async_add_executor_job(_install, hass, req, kwargs)
File "/usr/lib/python3.7/concurrent/futures/thread.py", line 57, in run
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/requirement s.py", line 81, in _install
progress_path.unlink()
File "/usr/lib/python3.7/pathlib.py", line 1287, in unlink
self._accessor.unlink(self)
FileNotFoundError: [Errno 2] No such file or directory: '/home/homeassistant/.ho meassistant/.pip_progress'
I am very newbie in the Linux stuff, HA is a big learning curve for me…
Thanks in advance!
