Was working fine for about 5 days. Added dark sky tags to configuration.yaml. Verified ok. Now, can’t get into it. Here are the errors when I do a status command:
- [email protected] - Home Assistant for homeassistant
Loaded: loaded (/etc/systemd/system/[email protected]; enabled; vendor preset: ena
Active: failed (Result: exit-code) since Tue 2018-04-24 19:32:25 EDT; 51s ago
Process: 511 ExecStart=/srv/homeassistant/bin/hass (code=exited, status=1/FAILURE)
Main PID: 511 (code=exited, status=1/FAILURE)
Apr 24 19:32:25 hassbian hass[511]: File "/srv/homeassistant/lib/python3.5/site-packages/requests/__in
Apr 24 19:32:25 hassbian hass[511]: from . import utils
Apr 24 19:32:25 hassbian hass[511]: File "/srv/homeassistant/lib/python3.5/site-packages/requests/util
Apr 24 19:32:25 hassbian hass[511]: from . import certs
Apr 24 19:32:25 hassbian hass[511]: File "/srv/homeassistant/lib/python3.5/site-packages/requests/cert
Apr 24 19:32:25 hassbian hass[511]: from certifi import where
Apr 24 19:32:25 hassbian hass[511]: ImportError: cannot import name ‘where’
Apr 24 19:32:25 hassbian systemd[1]: [email protected]: Main process exited, code=exi
Apr 24 19:32:25 hassbian systemd[1]: [email protected]: Unit entered failed state.
Apr 24 19:32:25 hassbian systemd[1]: [email protected]: Failed with result 'exit-code
I have no idea where to go from here.
Help!!!
