Hassbian version 1.23, hassbian-config install openzwave locks up
Trying to run hassbian-config to install openzwave, I get to a _Running setup.py install for cython … _ and it stops. I let it sit for over a day and it did not move. I tried it twice. Below is the second time I tried. I am trying a fresh load from Hassbian 1.23. This is a PI B with a 16 gig SD card.
pi@hassbian:~ $ sudo hassbian-config install openzwave
Open Z-Wave Installer for Hassbian
Copyright(c) 2016 Dale Higgs <https://gitter.im/dale3h>
Modified by Landrash for use with Hassbian.
Running apt-get preparation
Hit http://archive.raspberrypi.org jessie InRelease
Hit http://mirrordirector.raspbian.org jessie InRelease
Hit http://repo.mosquitto.org jessie InRelease
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit http://repo.mosquitto.org jessie/main armhf Packages
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Ign http://repo.mosquitto.org jessie/main Translation-en_GB
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
libudev-dev is already the newest version.
make is already the newest version.
python3-dev is already the newest version.
python3-dev set to manually installed.
python3-setuptools is already the newest version.
python3-setuptools set to manually installed.
The following extra packages will be installed:
  docutils-common javascript-common libgmp-dev libgmpxx4ldbl libjbig0
  libjs-jquery libjs-sphinxdoc libjs-underscore liblcms2-2 libp11-kit-dev
  libpaper-utils libpaper1 libssl-doc libtasn1-6-dev libtasn1-doc libtiff5
  libwebp5 libwebpdemux1 libwebpmux1 nettle-dev python3-docutils
  python3-jinja2 python3-markupsafe python3-pil python3-pygments python3-roman
  sphinx-common
Suggested packages:
  apache2 lighttpd httpd libgmp10-doc libmpfr-dev gnutls-doc gnutls-bin
  guile-gnutls liblcms2-utils texlive-latex-recommended texlive-latex-base
  texlive-lang-french fonts-linuxlibertine ttf-linux-libertine docutils-doc
  python-jinja2-doc python-pil-doc python3-pil-dbg ttf-bitstream-vera
  libjs-mathjax dvipng texlive-latex-extra texlive-fonts-recommended
  sphinx-doc
The following NEW packages will be installed:
  docutils-common javascript-common libgmp-dev libgmpxx4ldbl libgnutls28-dev
  libgnutlsxx28 libjbig0 libjs-jquery libjs-sphinxdoc libjs-underscore
  liblcms2-2 libp11-kit-dev libpaper-utils libpaper1 libssl-dev libssl-doc
  libtasn1-6-dev libtasn1-doc libtiff5 libwebp5 libwebpdemux1 libwebpmux1
  nettle-dev python3-docutils python3-jinja2 python3-markupsafe python3-pil
  python3-pygments python3-roman python3-sphinx sphinx-common
0 upgraded, 31 newly installed, 0 to remove and 0 not upgraded.
Need to get 7,730 kB of archives.
After this operation, 25.3 MB of additional disk space will be used.
Get:1 http://mirrordirector.raspbian.org/raspbian/ jessie/main libgmpxx4ldbl armhf 2:6.0.0+dfsg-6+rpi1 [21.6 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ jessie/main libjbig0 armhf 2.1-3.1 [27.5 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ jessie/main liblcms2-2 armhf 2.6-3+deb8u1 [116 kB]
Get:4 http://mirrordirector.raspbian.org/raspbian/ jessie/main libpaper1 armhf 1.1.24+nmu4 [21.4 kB]
Get:5 http://mirrordirector.raspbian.org/raspbian/ jessie/main libtiff5 armhf 4.0.3-12.3+deb8u3 [200 kB]
Get:6 http://mirrordirector.raspbian.org/raspbian/ jessie/main libgnutlsxx28 armhf 3.3.8-6+deb8u5 [12.6 kB]
Get:7 http://mirrordirector.raspbian.org/raspbian/ jessie/main libwebp5 armhf 0.4.1-1.2 [164 kB]
Get:8 http://mirrordirector.raspbian.org/raspbian/ jessie/main libwebpdemux1 armhf 0.4.1-1.2 [49.4 kB]
Get:9 http://mirrordirector.raspbian.org/raspbian/ jessie/main libwebpmux1 armhf 0.4.1-1.2 [54.6 kB]
Get:10 http://mirrordirector.raspbian.org/raspbian/ jessie/main docutils-common all 0.12+dfsg-1 [185 kB]
Get:11 http://mirrordirector.raspbian.org/raspbian/ jessie/main javascript-common all 11 [6,120 B]
Get:12 http://mirrordirector.raspbian.org/raspbian/ jessie/main libgmp-dev armhf 2:6.0.0+dfsg-6+rpi1 [552 kB]
Get:13 http://mirrordirector.raspbian.org/raspbian/ jessie/main nettle-dev armhf 2.7.1-5+deb8u2 [834 kB]
Get:14 http://mirrordirector.raspbian.org/raspbian/ jessie/main libtasn1-6-dev armhf 4.2-3+deb8u2 [85.0 kB]
Get:15 http://mirrordirector.raspbian.org/raspbian/ jessie/main libp11-kit-dev armhf 0.20.7-1 [62.4 kB]
Get:16 http://mirrordirector.raspbian.org/raspbian/ jessie/main python3-docutils all 0.12+dfsg-1 [360 kB]
Get:17 http://mirrordirector.raspbian.org/raspbian/ jessie/main libgnutls28-dev armhf 3.3.8-6+deb8u5 [576 kB]
Get:18 http://mirrordirector.raspbian.org/raspbian/ jessie/main python3-markupsafe armhf 0.23-1 [16.6 kB]
Get:19 http://mirrordirector.raspbian.org/raspbian/ jessie/main python3-pil armhf 2.6.1-2+deb8u3 [278 kB]
Get:20 http://mirrordirector.raspbian.org/raspbian/ jessie/main libjs-jquery all 1.7.2+dfsg-3.2 [97.5 kB]
Get:21 http://mirrordirector.raspbian.org/raspbian/ jessie/main libjs-underscore all 1.7.0~dfsg-1 [49.9 kB]
Get:22 http://mirrordirector.raspbian.org/raspbian/ jessie/main libjs-sphinxdoc all 1.2.3+dfsg-1 [41.1 kB]
Get:23 http://mirrordirector.raspbian.org/raspbian/ jessie/main libpaper-utils armhf 1.1.24+nmu4 [17.2 kB]
Get:24 http://mirrordirector.raspbian.org/raspbian/ jessie/main libssl-dev armhf 1.0.1t-1+deb8u6 [1,095 kB]
Get:25 http://mirrordirector.raspbian.org/raspbian/ jessie/main libssl-doc all 1.0.1t-1+deb8u6 [1,168 kB]
Get:26 http://mirrordirector.raspbian.org/raspbian/ jessie/main python3-roman all 2.0.0-1 [7,948 B]
Get:27 http://mirrordirector.raspbian.org/raspbian/ jessie/main python3-jinja2 all 2.7.3-1 [168 kB]
Get:28 http://mirrordirector.raspbian.org/raspbian/ jessie/main python3-pygments all 2.0.1+dfsg-1.1+deb8u1 [480 kB]
Get:29 http://mirrordirector.raspbian.org/raspbian/ jessie/main sphinx-common all 1.2.3+dfsg-1 [407 kB]
Get:30 http://mirrordirector.raspbian.org/raspbian/ jessie/main python3-sphinx all 1.2.3+dfsg-1 [271 kB]
Get:31 http://mirrordirector.raspbian.org/raspbian/ jessie/main libtasn1-doc all 4.2-3+deb8u2 [305 kB]
Fetched 7,730 kB in 10s (767 kB/s)
Extracting templates from packages: 100%
Preconfiguring packages ...
Selecting previously unselected package libgmpxx4ldbl:armhf.
(Reading database ... 38682 files and directories currently installed.)
Preparing to unpack .../libgmpxx4ldbl_2%3a6.0.0+dfsg-6+rpi1_armhf.deb ...
Unpacking libgmpxx4ldbl:armhf (2:6.0.0+dfsg-6+rpi1) ...
Selecting previously unselected package libjbig0:armhf.
Preparing to unpack .../libjbig0_2.1-3.1_armhf.deb ...
Unpacking libjbig0:armhf (2.1-3.1) ...
Selecting previously unselected package liblcms2-2:armhf.
Preparing to unpack .../liblcms2-2_2.6-3+deb8u1_armhf.deb ...
Unpacking liblcms2-2:armhf (2.6-3+deb8u1) ...
Selecting previously unselected package libpaper1:armhf.
Preparing to unpack .../libpaper1_1.1.24+nmu4_armhf.deb ...
Unpacking libpaper1:armhf (1.1.24+nmu4) ...
Selecting previously unselected package libtiff5:armhf.
Preparing to unpack .../libtiff5_4.0.3-12.3+deb8u3_armhf.deb ...
Unpacking libtiff5:armhf (4.0.3-12.3+deb8u3) ...
Selecting previously unselected package libgnutlsxx28:armhf.
Preparing to unpack .../libgnutlsxx28_3.3.8-6+deb8u5_armhf.deb ...
Unpacking libgnutlsxx28:armhf (3.3.8-6+deb8u5) ...
Selecting previously unselected package libwebp5:armhf.
Preparing to unpack .../libwebp5_0.4.1-1.2_armhf.deb ...
Unpacking libwebp5:armhf (0.4.1-1.2) ...
Selecting previously unselected package libwebpdemux1:armhf.
Preparing to unpack .../libwebpdemux1_0.4.1-1.2_armhf.deb ...
Unpacking libwebpdemux1:armhf (0.4.1-1.2) ...
Selecting previously unselected package libwebpmux1:armhf.
Preparing to unpack .../libwebpmux1_0.4.1-1.2_armhf.deb ...
Unpacking libwebpmux1:armhf (0.4.1-1.2) ...
Selecting previously unselected package docutils-common.
Preparing to unpack .../docutils-common_0.12+dfsg-1_all.deb ...
Unpacking docutils-common (0.12+dfsg-1) ...
Selecting previously unselected package javascript-common.
Preparing to unpack .../javascript-common_11_all.deb ...
Unpacking javascript-common (11) ...
Selecting previously unselected package libgmp-dev:armhf.
Preparing to unpack .../libgmp-dev_2%3a6.0.0+dfsg-6+rpi1_armhf.deb ...
Unpacking libgmp-dev:armhf (2:6.0.0+dfsg-6+rpi1) ...
Selecting previously unselected package nettle-dev.
Preparing to unpack .../nettle-dev_2.7.1-5+deb8u2_armhf.deb ...
Unpacking nettle-dev (2.7.1-5+deb8u2) ...
Selecting previously unselected package libtasn1-6-dev.
Preparing to unpack .../libtasn1-6-dev_4.2-3+deb8u2_armhf.deb ...
Unpacking libtasn1-6-dev (4.2-3+deb8u2) ...
Selecting previously unselected package libp11-kit-dev.
Preparing to unpack .../libp11-kit-dev_0.20.7-1_armhf.deb ...
Unpacking libp11-kit-dev (0.20.7-1) ...
Selecting previously unselected package libgnutls28-dev:armhf.
Preparing to unpack .../libgnutls28-dev_3.3.8-6+deb8u5_armhf.deb ...
Unpacking libgnutls28-dev:armhf (3.3.8-6+deb8u5) ...
Selecting previously unselected package libjs-jquery.
Preparing to unpack .../libjs-jquery_1.7.2+dfsg-3.2_all.deb ...
Unpacking libjs-jquery (1.7.2+dfsg-3.2) ...
Selecting previously unselected package libjs-underscore.
Preparing to unpack .../libjs-underscore_1.7.0~dfsg-1_all.deb ...
Unpacking libjs-underscore (1.7.0~dfsg-1) ...
Selecting previously unselected package libjs-sphinxdoc.
Preparing to unpack .../libjs-sphinxdoc_1.2.3+dfsg-1_all.deb ...
Unpacking libjs-sphinxdoc (1.2.3+dfsg-1) ...
Selecting previously unselected package libpaper-utils.
Preparing to unpack .../libpaper-utils_1.1.24+nmu4_armhf.deb ...
Unpacking libpaper-utils (1.1.24+nmu4) ...
Selecting previously unselected package libssl-dev:armhf.
Preparing to unpack .../libssl-dev_1.0.1t-1+deb8u6_armhf.deb ...
Unpacking libssl-dev:armhf (1.0.1t-1+deb8u6) ...
Selecting previously unselected package libssl-doc.
Preparing to unpack .../libssl-doc_1.0.1t-1+deb8u6_all.deb ...
Unpacking libssl-doc (1.0.1t-1+deb8u6) ...
Selecting previously unselected package python3-roman.
Preparing to unpack .../python3-roman_2.0.0-1_all.deb ...
Unpacking python3-roman (2.0.0-1) ...
Selecting previously unselected package python3-docutils.
Preparing to unpack .../python3-docutils_0.12+dfsg-1_all.deb ...
Unpacking python3-docutils (0.12+dfsg-1) ...
Selecting previously unselected package python3-markupsafe.
Preparing to unpack .../python3-markupsafe_0.23-1_armhf.deb ...
Unpacking python3-markupsafe (0.23-1) ...
Selecting previously unselected package python3-jinja2.
Preparing to unpack .../python3-jinja2_2.7.3-1_all.deb ...
Unpacking python3-jinja2 (2.7.3-1) ...
Selecting previously unselected package python3-pil:armhf.
Preparing to unpack .../python3-pil_2.6.1-2+deb8u3_armhf.deb ...
Unpacking python3-pil:armhf (2.6.1-2+deb8u3) ...
Selecting previously unselected package python3-pygments.
Preparing to unpack .../python3-pygments_2.0.1+dfsg-1.1+deb8u1_all.deb ...
Unpacking python3-pygments (2.0.1+dfsg-1.1+deb8u1) ...
Selecting previously unselected package sphinx-common.
Preparing to unpack .../sphinx-common_1.2.3+dfsg-1_all.deb ...
Unpacking sphinx-common (1.2.3+dfsg-1) ...
Selecting previously unselected package python3-sphinx.
Preparing to unpack .../python3-sphinx_1.2.3+dfsg-1_all.deb ...
Unpacking python3-sphinx (1.2.3+dfsg-1) ...
Selecting previously unselected package libtasn1-doc.
Preparing to unpack .../libtasn1-doc_4.2-3+deb8u2_all.deb ...
Unpacking libtasn1-doc (4.2-3+deb8u2) ...
Processing triggers for man-db (2.7.0.2-5) ...
Processing triggers for sgml-base (1.26+nmu4) ...
Processing triggers for shared-mime-info (1.3-1) ...
Processing triggers for install-info (5.2.0.dfsg.1-6) ...
Setting up libgmpxx4ldbl:armhf (2:6.0.0+dfsg-6+rpi1) ...
Setting up libjbig0:armhf (2.1-3.1) ...
Setting up liblcms2-2:armhf (2.6-3+deb8u1) ...
Setting up libpaper1:armhf (1.1.24+nmu4) ...
Creating config file /etc/papersize with new version
Setting up libtiff5:armhf (4.0.3-12.3+deb8u3) ...
Setting up libgnutlsxx28:armhf (3.3.8-6+deb8u5) ...
Setting up libwebp5:armhf (0.4.1-1.2) ...
Setting up libwebpdemux1:armhf (0.4.1-1.2) ...
Setting up libwebpmux1:armhf (0.4.1-1.2) ...
Setting up docutils-common (0.12+dfsg-1) ...
Setting up javascript-common (11) ...
Setting up libgmp-dev:armhf (2:6.0.0+dfsg-6+rpi1) ...
Setting up nettle-dev (2.7.1-5+deb8u2) ...
Setting up libtasn1-6-dev (4.2-3+deb8u2) ...
Setting up libp11-kit-dev (0.20.7-1) ...
Setting up libgnutls28-dev:armhf (3.3.8-6+deb8u5) ...
Setting up libjs-jquery (1.7.2+dfsg-3.2) ...
Setting up libjs-underscore (1.7.0~dfsg-1) ...
Setting up libjs-sphinxdoc (1.2.3+dfsg-1) ...
Setting up libpaper-utils (1.1.24+nmu4) ...
Setting up libssl-dev:armhf (1.0.1t-1+deb8u6) ...
Setting up libssl-doc (1.0.1t-1+deb8u6) ...
Setting up python3-roman (2.0.0-1) ...
Setting up python3-markupsafe (0.23-1) ...
Setting up python3-jinja2 (2.7.3-1) ...
Setting up python3-pil:armhf (2.6.1-2+deb8u3) ...
Setting up python3-pygments (2.0.1+dfsg-1.1+deb8u1) ...
Setting up sphinx-common (1.2.3+dfsg-1) ...
Setting up libtasn1-doc (4.2-3+deb8u2) ...
Setting up python3-docutils (0.12+dfsg-1) ...
update-alternatives: using /usr/share/docutils/scripts/python3/rst-buildhtml to provide /usr/bin/rst-buildhtml (rst-buildhtml) in auto mode
update-alternatives: using /usr/share/docutils/scripts/python3/rst2html to provide /usr/bin/rst2html (rst2html) in auto mode
update-alternatives: using /usr/share/docutils/scripts/python3/rst2latex to provide /usr/bin/rst2latex (rst2latex) in auto mode
update-alternatives: using /usr/share/docutils/scripts/python3/rst2man to provide /usr/bin/rst2man (rst2man) in auto mode
update-alternatives: using /usr/share/docutils/scripts/python3/rst2odt to provide /usr/bin/rst2odt (rst2odt) in auto mode
update-alternatives: using /usr/share/docutils/scripts/python3/rst2odt_prepstyles to provide /usr/bin/rst2odt_prepstyles (rst2odt_prepstyles) in auto mode
update-alternatives: using /usr/share/docutils/scripts/python3/rst2pseudoxml to provide /usr/bin/rst2pseudoxml (rst2pseudoxml) in auto mode
update-alternatives: using /usr/share/docutils/scripts/python3/rst2s5 to provide /usr/bin/rst2s5 (rst2s5) in auto mode
update-alternatives: using /usr/share/docutils/scripts/python3/rst2xetex to provide /usr/bin/rst2xetex (rst2xetex) in auto mode
update-alternatives: using /usr/share/docutils/scripts/python3/rst2xml to provide /usr/bin/rst2xml (rst2xml) in auto mode
update-alternatives: using /usr/share/docutils/scripts/python3/rstpep2html to provide /usr/bin/rstpep2html (rstpep2html) in auto mode
Setting up python3-sphinx (1.2.3+dfsg-1) ...
Processing triggers for libc-bin (2.19-18+deb8u9) ...
Changing to homeassistant user
Activating virtualenv
Installing latest version of cython
Collecting cython==0.24.1
  Downloading Cython-0.24.1.tar.gz (1.7MB)
    100% |████████████████████████████████| 1.7MB 36kB/s
Installing collected packages: cython
  Running setup.py install for cython ... \^canceled
^C^C^COperation cancelled by user
Creating source directory
chown: changing ownership of ‘/srv/homeassistant/src/libcec/build/install_manifest.txt’: Operation not permitted
chown: changing ownership of ‘/srv/homeassistant/src/platform/build/install_manifest.txt’: Operation not permitted
Cloning python-openzwave
Cloning into 'python-openzwave'...
remote: Counting objects: 9357, done.
remote: Compressing objects: 100% (28/28), done.
^CCreating libmicrohttpd directory), 684.01 KiB | 677.00 KiB/s
Downloading libmicrohttpd-0.9.19
--2017-05-12 20:15:03--  ftp://ftp.gnu.org/gnu/libmicrohttpd/libmicrohttpd-0.9.19.tar.gz
           => ‘libmicrohttpd-0.9.19.tar.gz’
Resolving ftp.gnu.org (ftp.gnu.org)... 208.118.235.20, 2001:4830:134:3::b
Connecting to ftp.gnu.org (ftp.gnu.org)|208.118.235.20|:21... connected.
Logging in as anonymous ... Logged in!
==> SYST ... done.    ==> PWD ... done.
==> TYPE I ... done.  ==> CWD (1) /gnu/libmicrohttpd ... ^C^Cpi@hassbian:~ $ ^C
pi@hassbian:~ $ ^C
pi@hassbian:~ $ ^C
libgnutls28-dev is already the newest version.
libgnutlsxx28 is already the newest version.
libssl-dev is already the newest version.
python3-sphinx is already the newest version.
  Using cached Cython-0.24.1.tar.gz
I gave up on mine and bought a PI3 which works a treat :slight_smile:
The web page says …
Hassbian is our customized operating system for the Raspberry Pi 3. It is the easiest way of installing Home Assistant.
Does Hasbian only support Pi 3? How big of an SD card is needed?
In the for what it worth category, I turned on verbose, here is my guess of where the script is stopping (Code.o).
 -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 build/temp.linux-armv6l-3.4/tmp/pip-build-wzl3nwdd/cython/Cython/Compiler/Visitor.o -o build/lib.linux-armv6l-3.4/Cython/Compiler/Visitor.cpython-34m.so
    cythoning /tmp/pip-build-wzl3nwdd/cython/Cython/Compiler/FlowControl.py to /tmp/pip-build-wzl3nwdd/cython/Cython/Compiler/FlowControl.c
    building 'Cython.Compiler.FlowControl' extension
    arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 -fPIC -I/srv/homeassistant/include -I/usr/include/python3.4m -c /tmp/pip-build-wzl3nwdd/cython/Cython/Compiler/FlowControl.c -o build/temp.linux-armv6l-3.4/tmp/pip-build-wzl3nwdd/cython/Cython/Compiler/FlowControl.o
    arm-linux-gnueabihf-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-z,relro -g -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 build/temp.linux-armv6l-3.4/tmp/pip-build-wzl3nwdd/cython/Cython/Compiler/FlowControl.o -o build/lib.linux-armv6l-3.4/Cython/Compiler/FlowControl.cpython-34m.so
    cythoning /tmp/pip-build-wzl3nwdd/cython/Cython/Compiler/Code.py to /tmp/pip-build-wzl3nwdd/cython/Cython/Compiler/Code.c
    building 'Cython.Compiler.Code' extension
    arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 -fPIC -I/srv/homeassistant/include -I/usr/include/python3.4m -c /tmp/pip-build-wzl3nwdd/cython/Cython/Compiler/Code.c -o build/temp.linux-armv6l-3.4/tmp/pip-build-wzl3nwdd/cython/Cython/Compiler/Code.o
Yeps that’s where mine stopped too.
I know the note said " Currently locked to this version since build fails for later versions.", but I thought I would try this command “pip3 install cython --verbose”.
I may try and lock it down to older version.
Also, I was going to order a Pi 3 anyway, but I was hoping to use my old one for the controller. So I just order my Pi 3, next I hope I can find my micro SD. :slight_smile:
Another thought, if I let it sit long enough, the Pi locks up. I had a second putty terminal opened. The one executing the install would not respond to ^C and the second one was at the prompt, it would not respond either, I had to power down/up the Pi.
BTW, thought might be out of diskspace, there was nothing about specs on the install main page, but look ok to me.
pi@hassbian:/opt/hassbian/suites $ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 15G 1.3G 13G 10% /
devtmpfs 87M 0 87M 0% /dev
tmpfs 91M 0 91M 0% /dev/shm
tmpfs 91M 4.4M 86M 5% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 91M 0 91M 0% /sys/fs/cgroup
/dev/mmcblk0p1 42M 21M 21M 51% /boot
I used the AIO installer as hassbian didn’t exist then. I use my old Model B’s for audio and mqtt server, so they are still useful :slight_smile:
[quote=“keithh666, post:7, topic:17767”]
I use my old Model B’s for audio and mqtt server[/quote]
Why did you not run it (mqtt) on the Pi3 with HASS? (I may have know the answer if I was more along in my HASS knowledge)
First, I misspoke, The Pi I grabbed was an A not a B. Looks like I would have had the same issues. I was on the original waiting list.
Back to the point, I went back a version to 0.19.1 and it installed. Not sure if it will work. I am still making dumb mistakes. My Pi 3 should be here today and SD card tomorrow, until then I will continue to play with what I have. I have some unused zwave devices I am playing with. BTW, my house right now is running on Almond+. The main thing that attracted me to HASS was the alarm decoder. I want to get my bearings on the zwave devices first so I can move my HA from Almond to HASS.
Here was my hack … “pip3 install --upgrade cython==0.19.1 --verbose”
This is like the 4th time I have imaged the SD card. I do have some suggestions for the hassbian web pages.
I think it is documented correctly, but maybe a couple of points might be more in your face. At least for us that tend to speed read :slight_smile:.
  1. The main page might say, in bold “Only Pi 3 are supported”.
  2. On the installation page, the install script mention might be better served at the top of the page. For each component, you might start with a command line example that could be cut and pasted.
    My first time reading the page, I googled each step and did it by hand. It sure is easier using the scripts.
Update, after STOPPING HASS, and NOT checking the USB on the OZWCP, I was able to connect and add my test device. One that I thought strange, it is a vision 2 relay switch, but under current values I see 3 on/off. I was expecting 2.
Bottom line, looks like the open zwave/ozwcp install worked.
Good to know :slight_smile: I did originally have my mqtt server on my PI3 but decided to move it over to my old PIB to save some resources for other things and now I may dedicate my CHIP to mqtt as that’s currently gathering dust :stuck_out_tongue:
Now looks like I get to pester the configuration people. :innocent:
I’m fairly certain your running out of ram.
I forgot about that when making the config scripts.
I could make a custom one for older pies if you want to use the old one?
You don’t need to for me, I was playing with the older one till my Pi 3 and memory arrived. Which by the way did yesterday and it is loading as I am typing. If you want to, I don’t mind testing. I did take the time to google how to tell the difference. I am runn Rev 0002, which is a Pi 1 B. So I did have 512 of memory.[quote=“Landrash, post:12, topic:17767”]
[/quote]
Could be, but as I said, 0.19 did install. I was having several issues getting my zwave up. Most of them is just being a newbie. I did not want to ask questions because I did not know if it was something I was doing or the way I installed. Since I was hacking the config scripts, I figured it would be considered “unsupported”.
If you want me to test the scripts on a Pi 1 B, let me know. Again, being a newbie, I may need some help in the test cases.
I do have one of each of the pi’s with exception of the A versions so testing that won’t be that bad on my part.
I’m adding it to the wishlist for Hassbian since there’s most likely more than you that will run into this problem.
My first pass with the Pi 3, I can not SSH into it. I found it on nmap …
Nmap scan report for 192.168.60.209
Host is up (0.00s latency).
MAC Address: B8:27:EB:FB:64:77 (Raspberry Pi Foundation)
I can ping it, but I get a “Software caused connection abort”.
I going to reimage the SD card, if I still have an issue, that will be for another thread. :wink:
Thanks again for your reply.
IIRC you have to enable ssh by putting a file (called ssh) in the boot directory (root dir in win 10 when exploring the card) if you haven’t got a keyboard/mouse/monitor connected when you initially boot (so that you can enable ssh thru the config program), i think it’s a new thing that they took ssh out of the boot procedure.
Not with hassbian. It’s already done.
OK, didn’t know that :slight_smile:
