I edited some setting in the zwave panel (the original one not the one in HA) after fisrt having stopped the HA service. After that i restarted my session and hassbian wont boot ( i cant even access the files via samba).
Any ideas what may have caused such a major corruption?
I have tried to read the sd card with my windows computer and it says it has to be formatted before it can be used. Is there any way i can at least save the configuration files???
if you open it on a Linux machine you should be able to open both partitions of the SD card. You can then navigate to the home assistant folder and pull your files.
I would also setup some type of backup of your files once you are up and running again.
