I wanted to halt a config check and restart so during a config check, I ctrl+c escaped.Now, no matter what I change or update, I always get the following error:
2017-12-07 05:36:21 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
when rebooting home assistant.
I have updated HASS to 59.2 and the error remains.Its like the config validation scripts were corrupted when I escaped while they were running. How do I fix this problem?
Full stack trace:
File "/usr/lib/python3.5/asyncio/tasks.py", line 241, in _step
result = coro.throw(exc)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 60, in async_setup_component
return (yield from task)
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
result = coro.send(None)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 159, in _async_setup_component
conf_util.async_process_component_config(hass, config, domain)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/config.py", line 628, in async_process_component_config
p_validated = platform.PLATFORM_SCHEMA(p_validated)
File "/srv/homeassistant/lib/python3.5/site-packages/voluptuous/schema_builder.py", line 221, in __call__
return self._compiled([], data)
File "/srv/homeassistant/lib/python3.5/site-packages/voluptuous/schema_builder.py", line 538, in validate_dict
return base_validate(path, iteritems(data), out)
File "/srv/homeassistant/lib/python3.5/site-packages/voluptuous/schema_builder.py", line 315, in validate_mapping
cval = cvalue(key_path, value)
File "/srv/homeassistant/lib/python3.5/site-packages/voluptuous/schema_builder.py", line 716, in validate_callable
return schema(data)
File "/srv/homeassistant/lib/python3.5/site-packages/voluptuous/validators.py", line 262, in __call__
v = schema(v)
File "/srv/homeassistant/lib/python3.5/site-packages/voluptuous/schema_builder.py", line 575, in validate_sequence
cval = validate(index_path, value)
return schema(data)
File "/srv/homeassistant/lib/python3.5/site-packages/voluptuous/validators.py", line 522, in __call__
if self.min is not None and not v >= self.min:
TypeError: unorderable types: str() >= int()
