Managed to install homeassistant/qemux86-64-homeassistant and hassio dockers - both are running
I can access homeassistant on port 8123 and I enabled hassio: on the config file but hassio is not loading in the homeassistant ui
I think it’s a networking issue my lan is on eth1 and hassio is on a 172.x.x.x subnet
any idea ?
eth1 Link encap:Ethernet HWaddr 52:54:00:13:cf:36
inet addr:192.168.0.90 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: 2604:2000:f8c2:1200:5054:ff:fe13:cf36/64 Scope:Global
inet6 addr: fe80::5054:ff:fe13:cf36/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:5050 errors:0 dropped:0 overruns:0 frame:0
TX packets:3009 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1132534 (1.0 MiB) TX bytes:3719685 (3.5 MiB)
hassio Link encap:Ethernet HWaddr 02:42:3b:95:45:9e
inet addr:172.30.32.1 Bcast:0.0.0.0 Mask:255.255.254.0
inet6 addr: fe80::42:3bff:fe95:459e/64 Scope:Link
RX packets:87 errors:0 dropped:0 overruns:0 frame:0
TX packets:243 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:5588 (5.4 KiB) TX bytes:24308 (23.7 KiB)
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
83fd3ba0d963 homeassistant/qemux86-64-homeassistant "/usr/bin/entry.sh..." 6 minutes ago Up 3 minutes home-assistant
43270b5f3d2c homeassistant/amd64-hassio-supervisor "/usr/bin/entry.sh..." 8 minutes ago Up 5 minutes hassio_supervisor
351aae1a418a portainer/portainer "/portainer" 25 minutes ago Up 25 minutes 0.0.0.0:9000->9000/tcp gracious_wescoff
"Id": "43270b5f3d2c145fa4c7e15e2a8b8f645c137c07f71d9a09a35b150d82abf46a",
"Created": "2018-04-01T22:48:46.66231575Z",
"Path": "/usr/bin/entry.sh",
"Args": [
"python3",
"-m",
"hassio"
"State": {
"Status": "running",
"Running": true,
"Paused": false,
"Restarting": false,
"OOMKilled": false,
"Dead": false,
"Pid": 4377,
"ExitCode": 0,
"Error": "",
"StartedAt": "2018-04-01T22:51:30.341671506Z",
"FinishedAt": "2018-04-01T22:51:19.567905279Z"
"Image": "sha256:bd35b458b8825ece844b0b7900c7d1de7a1eac50721f74daf818c85222d2e7d6",
"ResolvConfPath": "/var/lib/docker/containers/43270b5f3d2c145fa4c7e15e2a8b8f645c137c07f71d9a09a35b150d82abf46a/resolv.conf",
"HostnamePath": "/var/lib/docker/containers/43270b5f3d2c145fa4c7e15e2a8b8f645c137c07f71d9a09a35b150d82abf46a/hostname",
"HostsPath": "/var/lib/docker/containers/43270b5f3d2c145fa4c7e15e2a8b8f645c137c07f71d9a09a35b150d82abf46a/hosts",
"LogPath": "/var/lib/docker/containers/43270b5f3d2c145fa4c7e15e2a8b8f645c137c07f71d9a09a35b150d82abf46a/43270b5f3d2c145fa4c7e15e2a8b8f645c137c07f71d9a09a35b150d82abf46a-json.log",
"Name": "/hassio_supervisor",
"RestartCount": 0,
"Driver": "aufs",
"MountLabel": "",
"ProcessLabel": "",
"AppArmorProfile": "",
"ExecIDs": null,
"HostConfig": {
"Binds": [
"/var/run/docker.sock:/var/run/docker.sock",
"/var/run/hassio-hc.sock:/var/run/hassio-hc.sock",
"/var/run/dbus:/var/run/dbus",
"/usr/share/hassio:/data"
"ContainerIDFile": "",
"LogConfig": {
"Type": "json-file",
"Config": {}
"NetworkMode": "default",
"PortBindings": {},
"RestartPolicy": {
"Name": "no",
"MaximumRetryCount": 0
"AutoRemove": false,
"VolumeDriver": "",
"VolumesFrom": null,
"CapAdd": null,
"CapDrop": null,
"Dns": [],
"DnsOptions": [],
"DnsSearch": [],
"ExtraHosts": null,
"GroupAdd": null,
"IpcMode": "",
"Cgroup": "",
"Links": null,
"OomScoreAdj": 0,
"PidMode": "",
"Privileged": false,
"PublishAllPorts": false,
"ReadonlyRootfs": false,
"SecurityOpt": null,
"UTSMode": "",
"UsernsMode": "",
"ShmSize": 67108864,
"Runtime": "runc",
"ConsoleSize": [
0,
0
"Isolation": "",
"CpuShares": 0,
"Memory": 0,
"NanoCpus": 0,
"CgroupParent": "",
"BlkioWeight": 0,
"BlkioWeightDevice": null,
"BlkioDeviceReadBps": null,
"BlkioDeviceWriteBps": null,
"BlkioDeviceReadIOps": null,
"BlkioDeviceWriteIOps": null,
"CpuPeriod": 0,
"CpuQuota": 0,
"CpuRealtimePeriod": 0,
"CpuRealtimeRuntime": 0,
"CpusetCpus": "",
"CpusetMems": "",
"Devices": [],
"DiskQuota": 0,
"KernelMemory": 0,
"MemoryReservation": 0,
"MemorySwap": 0,
"MemorySwappiness": -1,
"OomKillDisable": false,
"PidsLimit": 0,
"Ulimits": null,
"CpuCount": 0,
"CpuPercent": 0,
"IOMaximumIOps": 0,
"IOMaximumBandwidth": 0
"GraphDriver": {
"Name": "aufs",
"Data": null
"Mounts": [
"Type": "bind",
"Source": "/var/run/dbus",
"Destination": "/var/run/dbus",
"Mode": "",
"RW": true,
"Propagation": ""
"Type": "bind",
"Source": "/usr/share/hassio",
"Destination": "/data",
"Mode": "",
"RW": true,
"Propagation": ""
"Type": "bind",
"Source": "/var/run/docker.sock",
"Destination": "/var/run/docker.sock",
"Mode": "",
"RW": true,
"Propagation": ""
"Type": "bind",
"Source": "/var/run/hassio-hc.sock",
"Destination": "/var/run/hassio-hc.sock",
"Mode": "",
"RW": true,
"Propagation": ""
"Config": {
"Hostname": "43270b5f3d2c",
"Domainname": "",
"User": "",
"AttachStdin": false,
"AttachStdout": true,
"AttachStderr": true,
"Tty": false,
"OpenStdin": false,
"StdinOnce": false,
"Env": [
"SUPERVISOR_SHARE=/usr/share/hassio",
"SUPERVISOR_NAME=hassio_supervisor",
"HOMEASSISTANT_REPOSITORY=homeassistant/qemux86-64-homeassistant",
"PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
"LANG=C.UTF-8"
"Cmd": [
"python3",
"-m",
"hassio"
"ArgsEscaped": true,
"Image": "homeassistant/amd64-hassio-supervisor",
"Volumes": null,
"WorkingDir": "",
"Entrypoint": [
"/usr/bin/entry.sh"
"OnBuild": null,
"Labels": {
"io.hass.arch": "amd64",
"io.hass.type": "supervisor",
"io.hass.version": "0.99"
"NetworkSettings": {
"Bridge": "",
"SandboxID": "7fd885fc0a04ac610a2fcf91b17345f1b02eae931970f475b6875e9a38fb445c",
"HairpinMode": false,
"LinkLocalIPv6Address": "",
"LinkLocalIPv6PrefixLen": 0,
"Ports": {},
"SandboxKey": "/var/run/docker/netns/7fd885fc0a04",
"SecondaryIPAddresses": null,
"SecondaryIPv6Addresses": null,
"EndpointID": "29326317b46d682c390d98638fe5111d09481121f7c8ad79789994229afc2296",
"Gateway": "172.17.0.1",
"GlobalIPv6Address": "",
"GlobalIPv6PrefixLen": 0,
"IPAddress": "172.17.0.2",
"IPPrefixLen": 16,
"IPv6Gateway": "",
"MacAddress": "02:42:ac:11:00:02",
"Networks": {
"bridge": {
"IPAMConfig": null,
"Links": null,
"Aliases": null,
"NetworkID": "57b4ad058ad7eb979c9f77ba0d6a4923d910fe410145d3ddf2cebc9c472ec3d5",
"IPPrefixLen": 16,
"IPv6Gateway": "",
"hassio": {
"IPAMConfig": {
"IPv4Address": "172.30.32.2"
"Links": null,
"Aliases": [
"hassio",
"43270b5f3d2c"
"NetworkID": "a43cfda2ce7f2ef6d808b1ffdd4c4c31988ea37c82fa7c181e575774b7b1e0f3",
"EndpointID": "8cfa8aaf7accbdd78cf41f9814e9b42c3abfa9e2e67b8b0c2470b21d7e38d6aa",
"Gateway": "172.30.32.1",
"IPAddress": "172.30.32.2",
"IPPrefixLen": 23,
"IPv6Gateway": "",
"MacAddress": "02:42:ac:1e:20:02"
"Id": "83fd3ba0d963eb6a7dc930641ce2ad179ee4f9b1e5d678609baff8ea4f1e8230",
"Created": "2018-04-01T22:50:54.581776228Z",
"Args": [
"python3",
"-m",
"homeassistant",
"--config",
"/config"
"State": {
"Running": true,
"Paused": false,
"OOMKilled": false,
"Dead": false,
"Pid": 4585,
"ExitCode": 0,
"Error": "",
"StartedAt": "2018-04-01T22:53:37.620172846Z",
"FinishedAt": "2018-04-01T22:52:18.544389192Z"
"Image": "sha256:fe981dfbd232cf6859654889e0b2e791460eaefa6ff160695fc399a99fe36851",
"ResolvConfPath": "/var/lib/docker/containers/83fd3ba0d963eb6a7dc930641ce2ad179ee4f9b1e5d678609baff8ea4f1e8230/resolv.conf",
"HostnamePath": "/var/lib/docker/containers/83fd3ba0d963eb6a7dc930641ce2ad179ee4f9b1e5d678609baff8ea4f1e8230/hostname",
"HostsPath": "/var/lib/docker/containers/83fd3ba0d963eb6a7dc930641ce2ad179ee4f9b1e5d678609baff8ea4f1e8230/hosts",
"LogPath": "/var/lib/docker/containers/83fd3ba0d963eb6a7dc930641ce2ad179ee4f9b1e5d678609baff8ea4f1e8230/83fd3ba0d963eb6a7dc930641ce2ad179ee4f9b1e5d678609baff8ea4f1e8230-json.log",
"Name": "/home-assistant",
"RestartCount": 0,
"Driver": "aufs",
"MountLabel": "",
"ProcessLabel": "",
"ExecIDs": null,
"HostConfig": {
"Binds": [
"/home/homeassistant/:/config",
"/etc/localtime:/etc/localtime:ro"
"LogConfig": {
"Config": {}
"NetworkMode": "host",
"PortBindings": {},
"RestartPolicy": {
"Name": "no",
"VolumeDriver": "",
"CapAdd": null,
"CapDrop": null,
"Dns": [],
"DnsOptions": [],
"DnsSearch": [],
"ExtraHosts": null,
"GroupAdd": null,
"IpcMode": "",
"Cgroup": "",
"Links": null,
"OomScoreAdj": 0,
"PidMode": "",
"UTSMode": "",
"UsernsMode": "",
"Runtime": "runc",
"ConsoleSize": [
0,
0
"Isolation": "",
"CpuShares": 0,
"Memory": 0,
"NanoCpus": 0,
"CgroupParent": "",
"BlkioWeight": 0,
"CpuPeriod": 0,
"CpuQuota": 0,
"CpusetCpus": "",
"CpusetMems": "",
"Devices": [],
"DiskQuota": 0,
"KernelMemory": 0,
"MemorySwap": 0,
"PidsLimit": 0,
"Ulimits": null,
"CpuCount": 0,
"CpuPercent": 0,
"IOMaximumIOps": 0,
"GraphDriver": {
"Name": "aufs",
"Data": null
"Mounts": [
"Type": "bind",
"Source": "/home/homeassistant",
"Destination": "/config",
"Mode": "",
"RW": true,
"Propagation": ""
"Type": "bind",
"Source": "/etc/localtime",
"Destination": "/etc/localtime",
"Mode": "ro",
"RW": false,
"Propagation": ""
"Config": {
"Hostname": "localhost",
"Domainname": "",
"User": "",
"AttachStdout": false,
"AttachStderr": false,
"Tty": false,
"OpenStdin": false,
"StdinOnce": false,
"Env": [
"LANG=C.UTF-8",
"PYTHONPATH=/usr/local/lib/python3.6/site-packages"
"Cmd": [
"python3",
"-m",
"homeassistant",
"--config",
"/config"
"Image": "homeassistant/qemux86-64-homeassistant",
"Volumes": null,
"WorkingDir": "/config",
"Entrypoint": [
"/usr/bin/entry.sh"
"OnBuild": null,
"Labels": {
"io.hass.machine": "qemux86-64",
"io.hass.type": "homeassistant",
"io.hass.version": "0.66.0"
"Bridge": "",
"SandboxID": "04cf3579cb6157b636641d0fe0dd91e547532637eb95eeb8f05bec1f2309c67c",
"Ports": {},
"SandboxKey": "/var/run/docker/netns/default",
"EndpointID": "",
"Gateway": "",
"IPAddress": "",
"IPPrefixLen": 0,
"IPv6Gateway": "",
"MacAddress": "",
"Networks": {
"host": {
"IPAMConfig": null,
"Links": null,
"Aliases": null,
"NetworkID": "7b1442704131e62244277122220d6016ccd1647ffb6a13a3c28c0bb2936363fc",
"EndpointID": "a125d6c525b4ea0054b533ec6c763f6d6fd2d2b0bfaeb4fa65cce5b1e50dbd84",
"Gateway": "",
"IPAddress": "",
"IPPrefixLen": 0,
"IPv6Gateway": "",
"MacAddress": ""
