Have just upgraded to 0.82.2 after missing a few releases and I know the api password has been deprecated.
I have followed the steps inthe docs re-setting up long life token. But I am gettingthe following erros
018-12-04 18:25:07.412060 INFO SIGTERM Recieved
2018-12-04 18:26:01.941814 INFO AppDaemon Version 3.0.2 starting
2018-12-04 18:26:01.943272 INFO Configuration read from: /config/appdaemon/appdaemon.yaml
2018-12-04 18:26:01.950549 INFO AppDaemon: Starting Apps
2018-12-04 18:26:01.972995 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2018-12-04 18:26:02.551458 INFO AppDaemon: HASS: HASS Plugin Initializing
2018-12-04 18:26:02.553952 INFO AppDaemon: HASS: HASS Plugin initialization complete
2018-12-04 18:26:02.556112 INFO Starting Dashboards
2018-12-04 18:26:02.605264 INFO Starting API
2018-12-04 18:26:02.622758 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2018-12-04 18:26:07.633921 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2018-12-04 18:26:12.643860 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2018-12-04 18:26:17.654411 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2018-12-04 18:26:22.664855 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2018-12-04 18:26:27.675312 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
my appdaemon.yaml is as follows
secrets: /config/secrets.yaml
log:
logfile: /config/logs/info.log
errorfile: /config/logs/err.log
accessfile: /config/logs/access.log
logsize: 100000
log_generations: 4
appdaemon:
threads: 10
api_port: 5000
api_ssl_certificate: /ssl/fullchain.pem
api_ssl_key: /ssl/privkey.pem
app_dir: /config/appdaemon/apps
plugins:
HASS:
type: hass
ha_url: https://192.168.0.195:8123
cert_path: /ssl/privkey.pem
cert_verify: true
token: eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiI3MTRiNzZiZDYwMzg0MzZmOTBhMGVjMDQxOTRkNjQ0MiIsImlhdCI6MTU0MzkwMjA5MywiZXhwIjoxODU5MjYyMDkzfQ.1JcGnmiAMFJ
hadashboard:
dash_url: http://127.0.0.1:5050
dash_dir: /config/appdaemon/dashboards
dash_ssl_certificate: /ssl/fullchain.pem
dash_ssl_key: /ssl/privkey.pem
This was working prior on hassio 0.78. but I had the Ha_key value there and API password enabled. the ha_url is accessible via the browser so no issues there
thanks
