Hassio 0.83.0 & Owntracks
Hi there,
It seems device_tracker (platform: owntracks_http) has been replace by the new owntracks component.
In the doc, it’s written:
URL: url given to you when setting up the integration
But the integration page just shows “This integration has no device”.
Is there anything I should do ? Or default URL ?
Thanks a lot in advance
OwnTracks is now using config entries. To set it up, go to the configuration panel and configure it there. When configured and MQTT is available, will automatically listen there too. (@kirichkov - #17034) (@balloob - #18759 ) (owntracks docs ) (breaking change)
Indeed I activated the component, but the configuration URL does not shows up (owntracks HTTP).
After deleting and creating the integration back, I see the URL… Seems like a first config bug ?
