Hassio 0.87.1 - Toggle on/off of a group seems to toggle individual entities of the group
Hi
I’ve just started using groups and have become a little confused as to the intended behavior of home_assistant.toggle when pointing to a group entity.
I would expect that the group switch should toggle (say from on to off), which in turn would turn off all entities in that group.
toggling the group switch (from off to on) would turn on all entities.
is this correct?
the reason for the question is that currently what i’m seeing is that each entity with in the group is being toggled independently. so devices that are on turn off, and during the same action, devices that are off are turning on.
thanks!
anyone help with this?
cheers
