Hassio 0.97.2 Watchdog found a problem with Home Assistant Docker
I been having random restarts of my hassio running in docker on ubuntu LTS 18.04.3. I cannot for the life of me figure out what is causing this. I’m not able to see any errors in the log because it doesn’t persist between restarts. I’m super frustrated and I don’t know what to do. Any suggestions will be much appreciated. I’m using nabu casa cloud as well.
This is my uptime graph:
here are my system logs that don’t show any anything other than restarts so it’s hard to debug this way also:
19-08-12 23:28:00 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker!
19-08-12 23:28:00 INFO (SyncWorker_37) [hassio.docker.interface] Clean homeassistant application
19-08-12 23:28:01 INFO (SyncWorker_37) [hassio.docker.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.97.0
19-08-12 23:28:06 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-08-12 23:28:36 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-08-12 23:28:41 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-08-12 23:28:46 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-08-12 23:30:51 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-08-13 00:30:34 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.97.2
19-08-13 00:30:34 INFO (SyncWorker_13) [hassio.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.97.0 to homeassistant/qemux86-64-homeassistant:0.97.2
19-08-13 00:30:34 INFO (SyncWorker_13) [hassio.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.97.2.
19-08-13 00:31:29 INFO (SyncWorker_13) [hassio.docker.interface] Stop homeassistant application
19-08-13 00:32:29 INFO (SyncWorker_13) [hassio.docker.interface] Clean homeassistant application
19-08-13 00:32:30 INFO (SyncWorker_6) [hassio.docker.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.97.2
19-08-13 00:32:35 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-08-13 00:33:05 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-08-13 00:33:10 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-08-13 00:33:15 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-08-13 00:35:35 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-08-13 00:35:35 INFO (MainThread) [hassio.homeassistant] Successful run Home Assistant 0.97.2
19-08-13 00:35:35 INFO (SyncWorker_32) [hassio.docker.interface] Cleanup images: ['homeassistant/qemux86-64-homeassistant:0.97.0']
19-08-13 01:15:40 INFO (SyncWorker_36) [hassio.docker.interface] Stop addon_15ef4d2f_esphome application
19-08-13 01:15:41 INFO (SyncWorker_36) [hassio.docker.interface] Clean addon_15ef4d2f_esphome application
19-08-13 01:15:41 INFO (SyncWorker_2) [hassio.docker.addon] Start Docker add-on esphome/esphome-hassio-amd64 with version 1.13.6
19-08-13 01:15:42 INFO (MainThread) [hassio.api.security] /host/info access from 15ef4d2f_esphome
19-08-13 01:15:58 INFO (SyncWorker_0) [hassio.docker.interface] Stop addon_core_mariadb application
19-08-13 01:16:01 INFO (SyncWorker_0) [hassio.docker.interface] Clean addon_core_mariadb application
19-08-13 01:16:01 INFO (SyncWorker_13) [hassio.docker.addon] Start Docker add-on homeassistant/amd64-addon-mariadb with version 1.2
19-08-13 01:16:17 INFO (SyncWorker_18) [hassio.docker.interface] Stop addon_core_mosquitto application
19-08-13 01:16:18 INFO (SyncWorker_18) [hassio.docker.interface] Clean addon_core_mosquitto application
19-08-13 01:16:19 INFO (SyncWorker_19) [hassio.docker.addon] Start Docker add-on homeassistant/amd64-addon-mosquitto with version 5.0
19-08-13 01:16:20 INFO (MainThread) [hassio.services.modules.mqtt] Set core_mosquitto as service provider for mqtt
19-08-13 01:58:23 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker!
19-08-13 01:58:23 INFO (SyncWorker_26) [hassio.docker.interface] Clean homeassistant application
19-08-13 01:58:23 INFO (SyncWorker_26) [hassio.docker.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.97.2
19-08-13 01:58:28 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-08-13 01:58:58 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-08-13 01:59:03 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-08-13 01:59:08 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-08-13 02:01:28 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-08-13 04:05:11 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-08-13 04:05:11 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hassio-addons/repository repository
19-08-13 04:05:11 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/AndBobsYourUncle/hassio-addons repository
19-08-13 04:05:11 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
19-08-13 04:05:11 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/esphome/hassio repository
19-08-13 04:05:12 INFO (MainThread) [hassio.store] Load add-ons from store: 63 all - 0 new - 0 remove
19-08-13 08:49:43 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker!
19-08-13 08:49:43 INFO (SyncWorker_24) [hassio.docker.interface] Clean homeassistant application
19-08-13 08:49:44 INFO (SyncWorker_24) [hassio.docker.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.97.2
19-08-13 08:49:49 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-08-13 08:50:34 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-08-13 08:52:49 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-08-13 10:05:11 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-08-13 10:05:11 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/AndBobsYourUncle/hassio-addons repository
19-08-13 10:05:11 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hassio-addons/repository repository
19-08-13 10:05:11 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
19-08-13 10:05:11 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/esphome/hassio repository
19-08-13 10:05:12 INFO (MainThread) [hassio.store] Load add-ons from store: 63 all - 0 new - 0 remove
19-08-13 11:15:35 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home Assistant Docker!
19-08-13 11:15:35 INFO (SyncWorker_14) [hassio.docker.interface] Clean homeassistant application
19-08-13 11:15:36 INFO (SyncWorker_14) [hassio.docker.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.97.2
19-08-13 11:15:41 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-08-13 11:16:11 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-08-13 11:16:16 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-08-13 11:16:21 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-08-13 11:18:36 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-08-13 11:25:27 INFO (SyncWorker_3) [hassio.docker.addon] Start Docker add-on hassioaddons/vscode-amd64 with version v0.6.2
19-08-13 11:25:28 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_vscode
