I wasn’t able to find this problem posted recently (or in the past with the same stack trace). This is occurring for me when going from hassio version 0.64.3 to any 0.65.x version. I get a 500 Internal Server Error, and the following is logged out:
2018-03-13 19:25:10 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 381, in start
resp = await self._request_handler(request)
File "/usr/lib/python3.6/site-packages/aiohttp/web_app.py", line 310, in _handle
resp = await handler(request)
File "/usr/lib/python3.6/site-packages/aiohttp/web_middlewares.py", line 88, in impl
return await handler(request)
File "/usr/lib/python3.6/site-packages/homeassistant/components/http/static.py", line 68, in staticresource_middleware
File "/usr/lib/python3.6/site-packages/homeassistant/components/http/real_ip.py", line 27, in real_ip_middleware
File "/usr/lib/python3.6/site-packages/homeassistant/components/http/ban.py", line 68, in ban_middleware
File "/usr/lib/python3.6/site-packages/homeassistant/components/http/auth.py", line 28, in auth_middleware
File "/usr/lib/python3.6/site-packages/homeassistant/components/http/view.py", line 100, in handle
result = await result
File "/usr/lib/python3.6/site-packages/homeassistant/components/frontend/__init__.py", line 481, in get
_is_latest(self.js_option, request)
File "/usr/lib/python3.6/site-packages/homeassistant/components/frontend/__init__.py", line 599, in _is_latest
return useragent and hass_frontend.version(useragent)
AttributeError: module 'hass_frontend' has no attribute 'version'
Seems like this is some sort of dependency issue, but I don’t know enough about python/home assistant architecture to understand what’s happening. I thought to some extent that if I was seeing this problem with the hassio docker image, everyone would, but that doesn’t seem to be the case (maybe something config related then?)
EDIT: Went into the running homeassistant container and checked out “/config/deps/lib/python3.6/site-packages/hass_frontend”, which doesn’t have the version method. Couldn’t say why.
