Hassio-addons/pulseaudio_fix
Hi I have just jumped from May release of Home Assistant to the August release and PulseAudio_Fix ADDON has stopped working. I have tried uninstalling it and reinstalling it to no avail. The error I am getting is:
“[homeassistant.components.hassio] Could not fetch stats for d4868bb1_pulseaudio_fix_dev: Container addon_d4868bb1_pulseaudio_fix_dev is not running”
Since uninstalling it and reinstalling it I am now unable to get it to start within the AddOn page.
This is for the dev branch. I have also tried the major branch too but I get exactly the same error.
Another problem that I am now having is that non of my Synology cameras are present. Its indicating that they are not available in the Dashboard. I found a thread mentioning it could be because the user does not have access to surveillance station within the Synology box. I have checked this and it does.
I don’t know if these two issues could be related, but any help would be greatly appreciated. One thing to note is that I am using the containerised Home Assistant setup.
Many thanks
Steve
I think the problem is stemming from when I start the Add-On, it is trying to start it but dying straight away. If I use Docker Events I can see the following. Is there anyway I can find out why it is dying.
Steve
2022-08-08T11:13:59.275010860+01:00 network connect 3c06c132d2c429341c389170a4925c78eb268b00c75232df90efdc9373ef5d3d (container=1060ad5d57173c3c788320f84174246f9e983f9dd1e1b2e5df6313083636109b, name=hassio, type=bridge)
2022-08-08T11:14:00.221648652+01:00 container start 1060ad5d57173c3c788320f84174246f9e983f9dd1e1b2e5df6313083636109b (image=d4868bb1/armv7-addon-pulseaudio_fix:3.4.1, io.hass.arch=armv7, io.hass.base.arch=armv7, io.hass.base.image=arm32v7/alpine:3.16, io.hass.base.name=alpine, io.hass.base.version=2022.08.0, io.hass.description=This add-on eliminates the problem of Device or resource busy on computers with an external ALSA and PULSEAUDIO caused by the docker container hassio_audio, io.hass.name=Alsa & PulseAudio Fix, io.hass.type=addon, io.hass.url=https://github.com/OPHoperHPO/hassio-addons/tree/master/pulseaudio_fix, io.hass.version=3.4.1, maintainer=Anodev https://github.com/OPHoperHPO, name=addon_d4868bb1_pulseaudio_fix, org.label-schema.build-date=, org.label-schema.description=This add-on eliminates the problem of ‘Device or resource busy’ on computers with an external ALSA and PULSEAUDIO caused by the docker container ‘hassio_audio’, org.label-schema.name=Alsa & PulseAudio Fix, org.label-schema.schema-version=1.0, org.label-schema.url=https://github.com/OPHoperHPO/hassio-addons/tree/master/pulseaudio_fix, org.label-schema.usage=https://github.com/OPHoperHPO/hassio-addons/tree/master/pulseaudio_fix, org.label-schema.vcs-ref=, org.label-schema.vcs-url=https://github.com/OPHoperHPO/hassio-addons/tree/master/pulseaudio_fix, org.label-schema.vendor=Anodev https://github.com/OPHoperHPO, org.opencontainers.image.created=2022-08-02 13:44:41+00:00, org.opencontainers.image.source=https://github.com/home-assistant/docker-base, org.opencontainers.image.version=2022.08.0)
2022-08-08T11:14:00.474932214+01:00 container die 1060ad5d57173c3c788320f84174246f9e983f9dd1e1b2e5df6313083636109b (exitCode=0, image=d4868bb1/armv7-addon-pulseaudio_fix:3.4.1, io.hass.arch=armv7, io.hass.base.arch=armv7, io.hass.base.image=arm32v7/alpine:3.16, io.hass.base.name=alpine, io.hass.base.version=2022.08.0, io.hass.description=This add-on eliminates the problem of Device or resource busy on computers with an external ALSA and PULSEAUDIO caused by the docker container hassio_audio, io.hass.name=Alsa & PulseAudio Fix, io.hass.type=addon, io.hass.url=https://github.com/OPHoperHPO/hassio-addons/tree/master/pulseaudio_fix, io.hass.version=3.4.1, maintainer=Anodev https://github.com/OPHoperHPO, name=addon_d4868bb1_pulseaudio_fix, org.label-schema.build-date=, org.label-schema.description=This add-on eliminates the problem of ‘Device or resource busy’ on computers with an external ALSA and PULSEAUDIO caused by the docker container ‘hassio_audio’, org.label-schema.name=Alsa & PulseAudio Fix, org.label-schema.schema-version=1.0, org.label-schema.url=https://github.com/OPHoperHPO/hassio-addons/tree/master/pulseaudio_fix, org.label-schema.usage=https://github.com/OPHoperHPO/hassio-addons/tree/master/pulseaudio_fix, org.label-schema.vcs-ref=, org.label-schema.vcs-url=https://github.com/OPHoperHPO/hassio-addons/tree/master/pulseaudio_fix, org.label-schema.vendor=Anodev https://github.com/OPHoperHPO, org.opencontainers.image.created=2022-08-02 13:44:41+00:00, org.opencontainers.image.source=https://github.com/home-assistant/docker-base, org.opencontainers.image.version=2022.08.0)
2022-08-08T11:14:00.760107099+01:00 network disconnect 3c06c132d2c429341c389170a4925c78eb268b00c75232df90efdc9373ef5d3d (container=1060ad5d57173c3c788320f84174246f9e983f9dd1e1b2e5df6313083636109b, name=hassio, type=bridge)
I installed Homeassistant supervised on raspberrypi 4 running on debian.
Please guide how to solve the following issues:-
  1. How do I autostart pulseaudio and connect to bluetooth? I have already installed pulseaudio and I am able to connect to bluetooth speaker manually via the terminal.
It is possible to autostart pulseaudio and connect to bluetooth speaker automatically once the homeassistant is started?
  1. How can I change the default media path?
Kindly guide.
