Because hassio is based on docker, you can’t just ssh in and install software. Check out https://home-assistant.io/hassio/run_local/ for the options available to make that work with hassio.
Hi there,
I also would love to have adb on my hassio, but I have not been able to do it so far.
Would you mind sharing your add-on configuration file (dockerfile, config.json and run.sh) if it works for you ?
Thank you !
