These are the particular settings in ZM (after clicking add new monitor)
On General Tab
Name: Whatever yo uwant to call your camera
Server: None
Source Type: Ffmpeg
Funtion: Select record etc (read the ZM docs to see what each function does)
Leave all other settings on here blank
On Source Tab:
Source Path rtsp://username_of_camera:[email protected]:554/onvif
remote method: UDP
Terget Colourspace: 32 bit colour
Capture width 1280
Height: 900
Otherwise, these also work withj ONVIF detection which may simply be easier…
To all, I would recommend connecting your camera’s to a dedicated CCTV platform first. Currently Zoneminder is the only platform that has a component for Home assistant. I have made a feature request here: Shinobi Camera Component for another really promsing brand new, free, cross platform cctv platform called Shinobi.
This way:
you only have to manage 1 camera component in HA
you ucan record on motion detect, trigger recording from HA sensors
All your recordings can be stored in one place (local/Lan or even ftp and email)
There is less performance impact on your HA environment
Same here - crashing/freezing with ffmpeg for Arlo/RIng cameras… using Hassio 0.57.2 on RasPi3, just noticed 0.57.3 and will report back if any changes…
I just want to be able to view a single camera as a feed when someone presses my doorbell. I no longer have a dedicated recorder due to moving into a rental property.
I’ve tried it both ways, and while zoneminder is great, it occasionally loses the video feed and fails to reconnect, leaving a blank view on hassio. disabling and reenabling the camera in zm fixes it, but that is getting old. Zoneminder is somewhat difficult to setup and needs a linux install.
I’m not a fan of Zoneminder. No audio last I checked, and I think only jpeg capable for storage. Also since it’s an older project, there’s a ton of very outdated information out there.
Recently setup my Home Assistant and was looking into piping in my Xiaomi IP Cameras before I came across this discussion
I am currently running 3 Xiaomi cameras on a RasPi 3 running motionEye and as being pretty new to this, wondering if there is a component for motionEye
I would suggest that instead of integrating each component seperately, I would spin up an instance of Zoneminder and then simply integrate the Zoneminder component.
I have been using an old version of Motion for the past year or so and it works great
I found though that running on a PI3 with an IP cam and a USB one connected, the PI3 was capable of running 3 cams at the most if it’s only used for the camera management.
Depending also of what you are doing with your pictures / movies
I had them saved on a remote disk where i could have access to them through a small web server.
then you just need to add a camere component for each of them through the IP and port configured in Motion and bingo, you will have a live feed of your camera through Hass
like that one
