Hi, I just bough everything to have Home Assistant running: sd card, raspberry PI 3, etc…
I installed Hassio in the SD card. After Etcher finished flashing I plug it (with a card reader) in my mac and I get this error “The disk you inserted was not readable by this computer.”
I mounted the SD card in the Raspberry PI connected via ethernet but router is not seeing a new device connected. I try to go to hassio.local:8123 but nothing.
I formatted the SD card into FAT32 and went through the procedure from the beginning (following written + video instructions) but same story. My mac cannot read the device (sd card) and the raspberry PI is not connecting via ethernet.
I also tried it with 2 different routers. But nothing. It has something to do with hassio and SD card I think
Great! I did not know if that would help or not. I just know I followed their instructions and have reflashed my card several times without trouble.
For future reference, another source says the above formatter is only good for cards up to 32 GB They recommend this tool for 64GB or larger. (in between, I am not sure which one.)
