Thanks for you fast reply Tomas.
Have tried adding requirements.txt containing the single line you suggested
Have placed that in the same folder as the appdaemon.yaml
have restarted appdaemon and tried restarting Home Assistant fully - unfortunately it still errors:
2020-11-06 09:56:46.204809 WARNING Error: ------------------------------------------------------------
2020-11-06 09:56:46.203230 WARNING Error: Traceback (most recent call last):
File "/usr/lib/python3.8/site-packages/appdaemon/app_management.py", line 875, in check_app_updates
await utils.run_in_executor(self, self.read_app, mod["name"], mod["reload"])
File "/usr/lib/python3.8/site-packages/appdaemon/utils.py", line 290, in run_in_executor
response = future.result()
File "/usr/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/lib/python3.8/site-packages/appdaemon/app_management.py", line 668, in read_app
self.modules[module_name] = importlib.import_module(module_name)
File "/usr/lib/python3.8/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "", line 1014, in _gcd_import
File "", line 991, in _find_and_load
File "", line 975, in _find_and_load_unlocked
File "", line 671, in _load_unlocked
File "", line 783, in exec_module
File "", line 219, in _call_with_frames_removed
File "/config/appdaemon/apps/hello.py", line 3, in
import httplib2
ModuleNotFoundError: No module named 'httplib2'
2020-11-06 09:56:46.196185 WARNING Error: ------------------------------------------------------------
2020-11-06 09:56:46.194905 WARNING Error: Unexpected error loading module: /config/appdaemon/apps/hello.py:
2020-11-06 09:56:46.193369 WARNING Error: ------------------------------------------------------------
I am running version 0.117.1of HA and AppDaemon 4 version: 0.3.1
To test I have merely added the import to the hello.py:
import appdaemon.plugins.hass.hassapi as hass
import httplib2
# Hellow World App
# Args:
class HelloWorld(hass.Hass):
def initialize(self):
self.log("Hello from AppDaemon")
self.log("You are now ready to run Apps!")
Thanks for your help again - there must be a simple answer
Cheers David
